locating a amp.
Old Apr 17, 2004 | 10:18 PM
redrider02's Avatar
Question locating a amp.
i have a mtx thunderform box, with 2 -10inch subs, 4 infinity speakers in place of the stock ones. i have a alpine 5 channel amp under the passenger seat. amp is getting so hot its cutting out. wanting to put two rockford amps under the seat. will the heat problem continue? or do i need another box for the subs so i can mount the amps up and out from under the seat? ive seen some nice speaker boxes that will allow me to do this thanks
Old Apr 17, 2004 | 10:53 PM
chimshady1's Avatar
Sounds more like the amp is being overloaded.Check to see if your wired to the correct ohm load for the amp.
Old Apr 17, 2004 | 11:01 PM
St Louis Lightning's Avatar
That is where most people mount the amps and I don't think overheating is a normal problem. Besides checking the ohm load also make sure you ran a large enough power and ground wire. Sounds like you should have ran at least 4 gauge.
-Mark
Old Apr 18, 2004 | 12:34 AM
AmoJohnny's Avatar
Could be ur amp is too weak for them subs. I have a JL 500/1 mounted under my passenger seat. Hooked up to my two 10" JLw6-es. After hour drives of blastin the subs at high volume/power...the amp BARELY starts gettin warm. I know for a fact that my amp has almost twice what my subs can handle...so im safe.
Old Apr 18, 2004 | 08:48 AM
AMP's Avatar
AMP
Old Apr 18, 2004 | 10:37 AM
RED WING NUT's Avatar
You should've kept the amps I sold you. No problems with heat for me. Put a hard cover on that bed and put the amps back there.
Old Apr 18, 2004 | 12:03 PM
ND4SPD's Avatar
sorry to hijack your thread...I just got my amp and subs yesterday and will be installing them hopefully today. Not a super guru guy on stereo stuff. Where is the remote wire, can I just pull the stock deck out to get to it. Also is there a spot for the RCA plugs back there too. Thanks.
Old Apr 18, 2004 | 12:44 PM
Twisted99's Avatar
I have a 54 channel MTX under the passenger side seat. It would overheat and shut down if I cut the volume about a certain level. I added a two channel to power the subs as I had been running them bridged off the rear of the 4 channel...anyway....I was running 4 gauge to a T and then 8 gauge to the individual amps. still had problems with the 2 channel amp for the subs..went to 4 gauge throughout and No more worries.....
