tail light PS, slight miss starting
Old Apr 14, 2004 | 11:33 AM
jakemarietta's Avatar
to really bug me. Left rear tail light went out after driving in rain. Search indicated there are gaps in fender causing light to short out? Hope this is covered by my extended warranty, time has run out on 2kL, but only has 15k miles? Under slow speeds while turning, the power steering makes a ppsssshhhh sound and is getting louder. Search turned up nothing--any ideas? Seems to be a slight miss/running just a little rough. Replaced #4 coil coil pack last year, but really didn't cure problem. Seems like I remember something about a fluid leak somewhere that might be causing this?
appreciate any help you guys can give. This is unacceptable for a truck with only 15k that is always babied!
Old Apr 15, 2004 | 12:07 PM
48 "looks" and no ideas?
come on guys, need a little help here! My expertise definitely leaves at lot to be desired, but yours doesn't. Bump
Old Apr 15, 2004 | 12:12 PM
Silver_2000's Avatar
Some folks had heater hose leak on to the pass side rear coil..
You might check that
If you PowerSteering is making noise first step is to be sure its not under lor over full...
Doug
Old Apr 16, 2004 | 09:49 AM
Silver, appreciate your reply
Will check for power steering fluid level and heater hose leak. Thanks!
