What is the fattest tire I can run on a stock rim??
I have burned up my F1's some how
, and I need to get another set of tires. Can I run a 305/60 on a stock L rim?
What tires have people had good luck with?
Nitto?
Toyo?
Or should I stick with the F1's?
, and I need to get another set of tires. Can I run a 305/60 on a stock L rim?What tires have people had good luck with?
Nitto?
Toyo?
I've been through 3 sets of F1's on my 2000 and currently have the Nitto 555's. I like the Nitto's so much that i'll never pay goodyear another cent! The F1 and the 555 have the same treadware, but the 555's are lasting alot longet than any F1 ever did. A 305 will fit on the back with no problems, but i think you'll only find that size in the 555R drag radials. Hope this helps.
That 60 seires tire is like 31 inches tall and will throw your speedo off almost 9 MPH, It will raise your gear ratio and I garuntee you won't be spinning them as easy.
There are a few 305/35/18 searies that will lower you and do the opposite
http://www.discounttiredirect.com/di...foTireMath.jsp
