G-tech performance meter
How accurate is a g-tech pro comp performance meter? They said it measures horsepower and torque, as well as a ton of other stuff. I was curious how accurate the horsepower and torque readings are. If anyone knows, please tell me. I have a new g-tech coming in the mail and would like to know some info to tide me over while I wait
Ihave the original g tech and im not sure how acurate it is but i use it to test mods imporvement. I plan on making some runs when my port s/c comes in then go to the house put the ported s/c on and see what the gains are.
I have taken mine to the track and it was off by a 5 hundreths of a second in E.T. and it was a few mph high. This was in the 1/8th, I havent ever taken it down the 1/4.
I use mine to measure changes. If you test on the same road going the same direction you should get very consistant results. So with every mod that you add you should be able to take the truck out and get accurate before and after results.
-Mike
-Mike
accurate, not necessarily. From my general understanding it is decent and as shown above, it can be accurate for certain people. More important than accurate however, is that it is consistent. I wouldn't use it so much as a tool to determine your quartermile, but it definately is a good tool to determine how much better a mod has benefitted you.
HP and Torque w/ G-Tech Competition depends on the Vehicle Weight you Enter.......I Guestimated 4800 lbs....yet my HP and TQ
are below 400/500 w/G-Tech. ( I Dyno higher)
At Track ................... G-tech same run
60 ft 1.954 ,,,,,,,,,,,, 2.123
330 5.292 ............... 5.432
1/8 8.047 @89.03 ,,,,,,,,,,,,,,, 8.084@93.27
1/4 12.470 @111.37 .............. 12.309 @116.26
The G-Tech is not as good as a drag strip for getting true numbers and speeds, but is great for testing new mods. The key to it is to know as accurately as possible how much your truck weighs with you in it...
<<<<<<<<<<The key to it is to know as accurately as possible how much your truck weighs with you in it...>>>>>>>>>>>
Weight of truck Entered.......Is only for HP and TQ
Your G-Tech Times are Not associated w/the weight you enter
My Manuel for the pro says you have to enter the correct distance your track uses for starting. This can vary from track to track.... most are like 12 inches. I forgot what they call it, but it's in the book. This will throw the final numbers off if you don't correctly input the distance. It also says most tracks don't calibrate there equipment very often so 2 different tracks will not have the same results.
You also have to remember that dragstrips take an average of your speed that prints onto the timeslip.
They record your speed something like 60' before the end and at the end and average the two together for your speed.
So the G-tech is really more accurate as far as that is concerned.
The G-tech is not to be used to compare to a dragstrip....it is used to compare to its own measurements.
Read the entire manual that comes with one and it explains all this in detail.
