? about spark plugs
Old Apr 11, 2004 | 04:46 PM
Blown5Pnt4's Avatar
? about spark plugs
Hey guys...
first for all you search ****'s I did do one but couldnt find the info I need.
I should be getting a new truck very soon and plan to change the plugs to accomodate my 6# pulley. In the search I did alot of you mention a special snap on tool to make things ALOT easier but none mention the part number could someone please tell me it ???
Also just wanna check my list of tools needed to do the job to make sure its all I'll need....
1- Snap On 6" 5/8 Spark plug socket
1- 3/8 ratchet
2- 6" extentions
2- 3" extentions
1- 1/4 ratchet
2- 2" extentions
1- 4" extention
1- 7mm swivel socket
1- can of air to spray grime and grit out
Thanks Josh
Old Apr 11, 2004 | 04:51 PM
fractaldragon's Avatar
I borrowed my mechanic's Snap-On stuff to change mine and it made life alot easier. Here are the part #'s I have:
7 mm swivel socket TMUSM7 $28.50 (can get one at Sears cheaper)
5-7/8" long 5/8" spark plug socket S9720KA $53.00
"Ball joint" universal (think it is actually a impact swivel) IPF800 $30.25
Old Apr 11, 2004 | 04:53 PM
Blown5Pnt4's Avatar
Thanks Dragon.
I wanna make it easy on me cuz its my first time changing plugs on the truck.
Old Apr 11, 2004 | 09:17 PM
denny0328's Avatar
Telescoping magnet is a good investment!!! Saved my a$$ a couple of times...
I also used a swivle spark plug socket, it helped m out a little too
-dennis
Old Apr 11, 2004 | 10:36 PM
Robert Francis's Avatar
Several in here in changing plugs mention the "Snap On Spark Plug Socket". But I'm not sure why. I used a standard plug socket with no probem. Just make sure the rubber insert in the plug socket does hold the plug in place and when you take it off the plug, the insert doesn't come off with it on the plug. Do get the telescoping magnet as mentioned. You may need it to latch onto a couple of the coil pack bolts. Do get the 7mm 1/4 drive swivel socket. only used it on one plug - the third one back on the drvers side. I just could not get that coil pack bolt back on without it. The job is not as hard as it may first look - but the first time you do it, expect to spend 2.5-4 hours on it. This is not a good job to start on at 6pm when you've got a date with your girlfriend at 8pm. Unless you've got small thin fingers, the coil pack bolts are just hard to get at. You need some patience. Be careful putting the plugs back in - you can't see anything down there. I only loosened one item and moved it aside - the power steering pump resevoir. I also took off the injector plugs for a little more room.
Old Apr 11, 2004 | 10:39 PM
LTNBOLT's Avatar
Here is a pick of the tools that I use. The 7mm swivel is a good replacement for the 1/4" breaker bar.
Old Apr 11, 2004 | 10:49 PM
Blown5Pnt4's Avatar
Thanks for the info guys...I'm looking at doin it all as part of a mod day to get everything ready by the 24th. Probably next weekend. I dont have any of the needed swivels so I gotta make a run to the sears or something.
Josh
Old Apr 11, 2004 | 11:10 PM
Don's Bolt's Avatar
Chuck you just about have it right there
I have found something that makes it even easier to change the plugs, so Josh don't waste your time getting the snap on tool.
I have found that with a normal Craftsmans spark plug socket. You just add a one inch extension, then a swivel and then two 12 inch extensions to your 3/8 socket. The one inch extension makes it allmost the same as the expensive Snap On tool. I think it works even better than the snap on tool. By putting the one inch extension, the swivel is at the top of the hole to the plugs and you can into any hole perfect.
The rest of Chucks tools are right on, just replace his 3 inch extension with the one inch extension. Trust me it makes it a lot easier.
here is what I use
Chuck next time you do plugs try my setup and let me know what you think.
Old Apr 11, 2004 | 11:27 PM
Blown5Pnt4's Avatar
Thanks for the info Don. I'll try it out before taking the leap into the snap-on stuff. I'm still gonna have to go hit up the store though...lol
Josh
Old Apr 11, 2004 | 11:37 PM
Don's Bolt's Avatar
Josh
Sears has everything you need
My tools are all Craftsman
By the way I drove your truck yesterday and it is one of those freek trucks that with just a 2# lower runs as strong as many I have driven with 4# or bigger pulleys.
12.60 with just a 2# lower, now imagine what it will do with a 6# pulley.
Old Apr 11, 2004 | 11:41 PM
Blown5Pnt4's Avatar
LOL good to know Don. Thanks alot for hooking me up with Jamie. its due here tomorrow and I cant wait. I got a mod day all planned already. LoL
Josh
Old Apr 11, 2004 | 11:46 PM
Don's Bolt's Avatar
Josh
You will love the truck
I am sure it will need a little more cleanup, judging from your posts. We just did a quick clean up job yesterday, as we had 2 other trucks to work on at the same time. I just threw a real quick wax job, on the hood and sides, never got the roof, tailgate or wheels. I left those for you, hehe.
Old Apr 11, 2004 | 11:50 PM
Blown5Pnt4's Avatar
I'll be sure to take care of all that.....if you guys make it down to the E-Town shootout, you'll get to see it again... I cant wait to have a truck again....these past 2weeks have been killing me.
Josh
Old Apr 11, 2004 | 11:54 PM
Don's Bolt's Avatar
OK go to bed now bud
Not sure what E-Town events I will make
I will be at Fun Ford Weekend, Fords at E Town, and at JDM tuesday and wednesday this week.
Old Apr 11, 2004 | 11:56 PM
Blown5Pnt4's Avatar
LoL I cant sleep yet.
well april 24th is the big shootout that Tom(halflife) organized.
Josh
