What gives???
Old Apr 11, 2004 | 04:01 PM
ND4SPD's Avatar
What gives???
I don't get it, how can I only be seeing 11 psi on my Autometer boost gauge. I thought maybe it wasn't hooked up right so I decided to do it again making sure that it was tight and still only see 11 with a 6lber. Is there a trick to attach the hose to the gauge or something....Any ideas guys! The truck runs great and pulls good but maybe it should be pulling better...
Old Apr 11, 2004 | 04:14 PM
LatemodelRacer2's Avatar
IS it tee'd into the place under the dash? Try borrowing a gauge from a local guy and see if his gauge reads right.
Old Apr 11, 2004 | 04:20 PM
ND4SPD's Avatar
Yeah I have it teed into the hose under the dash and only the line from the S/C, I don't have the Map sensor hose spliced in because I don't need the stock gauge, that shouldn't be affecting anything though right...I think I migh go buy one at pebboys and then just return it after I use it to make sure that my gauge works ok.
Old Apr 11, 2004 | 04:28 PM
Sounds like something id do
Old Apr 11, 2004 | 04:47 PM
fractaldragon's Avatar
Got the right size tee? If there is any leak due to the the wrong tee it won't read accurately!
