Track results...improved ET by .55
Old Apr 11, 2004 | 01:00 AM
RollinLimp2001's Avatar
Well I went back out to the track last night to see what my truck would run since I put my new mods on. Here's how it looked...
My first time at the track PERIOD:
Mods:
-Ported Eaton
-FTVB
Slip:
60' - 2.19
330' - 5.86
1/8 - 8.89@81.18
1/4 - 13.99@80.57 (let off early...ran a 99mph later that night)
My second time at the track:
Mods:
-4# lower
-JLP forced induction
-JLP tuned Predator
-Denso IT22s
-plus mods from above
Slip:
60' - 2.21
330' - 5.78
1/8 - 8.73@83.25
1/4 - 13.44@103.35
I'm still happy with the improvement but still feel that I should be in the 12's with the mods I have. Stock L's are running 13.4's
Maybe it's the track I go to because there was another 03 there that supposedly had a chip and exhaust that ran a couple low 14's. Anyone notice a big difference between tracks they go to?
Old Apr 11, 2004 | 01:07 AM
Casey02L's Avatar
Your 60ft is hurting your ET bad. You should be able to get a 1.9 something 60ft. The track must be pretty bad; time for some slicks.
Old Apr 11, 2004 | 01:22 AM
Sharpshooter's Avatar
Re: Track results...improved ET by .55
Not only tracks, but choosing the correct lane may make a difference. The last time I was at the track, one lane was slippery and the other stuck decently.
Old Apr 11, 2004 | 02:02 AM
Rob_02Lightning's Avatar
YOU NEED MORE TIMING
RollinLimp2001 it is DEF your 60ft thats killing you.
They claim every 1/10th off the 60 CAN net you as much
as 2/10th's on the other end. Get that 60ft to a 1.9 on street tires, and a 1.6 - 1.78 on slicks, and you'll pick up another .55
CONGRATS and don't worry, plenty more Et to be had just the way you are, Def 12's with a good hook up.
Old Apr 11, 2004 | 11:11 AM
tallimeca's Avatar
christ
your 60 ft times look like your racing a bicycle!!!!
Power is there.....just gotta hook. You manage a 1.95 60 and you'll run a 12.873 ......that's my prediction!!!
Old Apr 11, 2004 | 12:06 PM
Well thanks guys. I knew my 60' was holding me back, but I may have to go to a different track if I still want to run on the F1's. I was watching the 60' of other vehicles that night and not many dipped below 2.0 I may have been able to push it a little bit more off the line since I didn't feel any traction loss on the two runs I was able to get off Friday night. I guess I just need more practice.
Another question...Will a 60' also affect your MPH?
Old Apr 11, 2004 | 12:12 PM
quickcanuck's Avatar
I feel your pain!!!! My first time at the track I ran a 12.59 with my mods. My 60FT was a ridiculous 2.35. Nice. I had a ton of fun and KNOW that it was ME not the truck for the bad 1/4 mile times.
And yes, the MPH will be affected by your 60ft times. Good luck, and congrats on the good ET!
Old Apr 11, 2004 | 01:22 PM
D Davis's Avatar
Seat time in your vehicle may help as much as your mods.I was able to cut almost 1/2 sec. just learning to launch. How are you launching "rpm etc." ? if you didn't feel it spin you got more to hammer. PRACTICE, PRACTICE, PRACTICE.
GOOD LUCK it'll come down
Old Apr 11, 2004 | 01:31 PM
Thanks for the encouragement. I've been launching directly off idle on all my runs except for one. I raised the RPM to about 1000. I got alittle bit better 60', but like you said I think I could have pushed it alittle more since I felt no wheelspin.
Looking back at my slips I noticed that a WRX that I raced only got a 60' of 2.06...so even with all-wheel drive sub 2.0s on this track are not the norm.
Old Apr 11, 2004 | 08:27 PM
D Davis's Avatar
With every vehicle having it's own sweet spot, seat time is important, since you got a little better going up to 1,00 rpm try a little more, " I wouldn't go above 1,500 ".
without traction lost "yet" come off your launch rpm and stab it hard , see if it still hooks, if so up the rpm a hair. if it spins try lowering tire pressure a couple #s. check with others about how low to go w/F-1s I can't remember.
just keep hunting for your trucks sweet spot before you get more mods.
Old Apr 11, 2004 | 11:30 PM
Ya I lowered the tire pressure this time to about 25 psi like others mentioned to do on the F1's. Only thing is that I don't think I changed my launch enough to take advantage of the traction...I was still rolling into the throttle gradually almost till I hit second gear. But I will try and get more practice to see what I can do...thanks
