Is this a big screw-up?Cam Install?
Old Apr 8, 2004 | 11:56 PM
chimshady1's Avatar
Does it hurt to install the cams with the lifters and rockers alreadys installed?1/4 turn a time in sequence to 89 ft lbs?
Old Apr 9, 2004 | 06:52 AM
Rob_02Lightning's Avatar
Chim,
No answers yet hu ?
BUMMER
Why don't you e-mail Chris, he should be able to answer that one
GOOD LUCK Bro
BTW
Cecil is next Saturday........
Old Apr 9, 2004 | 07:00 AM
cpeapea's Avatar
it shouldnt hurt them in my opinion, just be carefull when unbolting then. 89ftlbs seems rights, but chris (i think) said that some of his co-workers just impact them on with a gun
Old Apr 9, 2004 | 07:59 AM
tommylightning's Avatar
I hope you mean 89 Inch Lbs. I would just go around a few times to make sure they are all seated. When you go around the first time you may have more tension on some than others because of the valve springs. Good luck.
Old Apr 9, 2004 | 08:35 AM
superfords's Avatar
chim, I have never tried it that way, but it would probably work ok in a pinch. my only concern would be getting accurate torqe readings with the springs pushing upwards on the cams and caps, but it'd probably be ok. just be careful, the threads in the cam towers are tiny and aluminum, it might be easy to strip on out if there is to much tension when trying to compress those springs.
like tommy said though, check the final torque spec several times.
oh, and yeah, its 89INCH LBS. 89ft/lbs is a little high
I think cpeapea was thinking about the bolts on the front of each cam to hold the gear on.
good luck.
later,
chris
Old Apr 9, 2004 | 06:08 PM
chimshady1's Avatar
What a relief to hear that.Thanks everyone.And yes i meant to say inch lbs. It didnt seam to be much pressure on the cam.Hopefully all works well.Thanks again
Old Apr 9, 2004 | 06:40 PM
cpeapea's Avatar
yea, i was refering to cam gears, my bad
