Not getting enough fuel
Old Apr 8, 2004 | 06:36 PM
Warren86's Avatar
This morning on my way to work I went to change lanes and hit the throttle to about 3/4 and just as the SC started to whine it almost died. I barely had enough power to pull off the road. At idle it seemed fine and even revved ok. I started driving again it was fine as long as there was no boost. As soon as the guage went above 0 it would start to die again.
I figured it was a hose that had come loose but didn't find any. On my way back home it would barely run at all and the AF gauge was reading very lean. I thought it may be the fuel filter and changed it with no luck.
How do I check the fuel pressure? Is it common for fuel pumps to go on these?
any advise would be appreciated,
Old Apr 8, 2004 | 06:46 PM
White01's Avatar
There has been posts of peoples fuel pump clamps coming off in the tank, causing what you describe. I think the problem was on 99 and 00 models. Might want to check that first. Good luck!
Rich
