ses light need HELP
Old Apr 8, 2004 | 02:39 PM
Grandmastr's Avatar
ses light need HELP
0171
0174
these 2 codes came up about a month ago, i cleared the computer and never had a problem since
yesterday, it came on again
the same two codes
bank 1 & 2 Lean
i cleared them again and did a self test with my boys computer
this came up
0243 check service manual
p1780 tcs
p1101 maf sensor out of range
1124 tp sensor out of range
hopefully this pinpoints my problem better
what should i do to fix this?
Old Apr 8, 2004 | 02:44 PM
Silver_2000's Avatar
Re: ses light need HELP
Originally posted by Grandmastr
0171
0174
the same two codes
bank 1 & 2 Lean
this came up
p1780 tcs
from here
http://www.svtlightnings.com/scantoo...tc%20codes.htm
P0243 Wastegate Solenoid A Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
Old Apr 8, 2004 | 02:50 PM
Grandmastr's Avatar
what is that?
Old Apr 8, 2004 | 03:21 PM
what is that?
You need the letter P or b or whatever to be sure thats the right code.....
Wastegate is typically on a turbo
Doug
Old Apr 8, 2004 | 06:13 PM
halflife's Avatar
HOW DO you do a self test?
Old Apr 9, 2004 | 01:37 AM
Grandmastr's Avatar
it was on his scanner
said to start the engine, and it was messing around the engine, reving it up and checking all kinds of sensors
pretty neat scanner
Old Apr 9, 2004 | 11:40 AM
jgstang67's Avatar
do you have an oil breather cap??
Old Apr 9, 2004 | 12:59 PM
Grandmastr's Avatar
nope
Old Apr 9, 2004 | 01:04 PM
Stl01SVT's Avatar
Do you have a K&N filter? If so, the MAF might be contaminated from the filters oil. This happened to my truck, and the MAF had to be replaced.
Old Apr 9, 2004 | 02:42 PM
Grandmastr's Avatar
yea i have a k&n
but its a brand new filter
does it come wit oil on it already?
i also just pulled 2 spark plugs
they look normal, no signs of detontion or running lean
Old Apr 9, 2004 | 02:43 PM
Grandmastr's Avatar
how do you test out if the maf is fine or not, is there a voltage test?
Old Apr 11, 2004 | 02:57 PM
Grandmastr's Avatar
ttt
