Oil Filter...
Old Apr 7, 2004 | 12:57 PM
SVTF150Lghtn's Avatar
Oil Filter...
Was just curious to what anyone knows about oil fliters and which brand they think is the best. Im currently using a Fram, but thinking of going to the K&N and was wondering if the price difference is worth it.
Old Apr 7, 2004 | 01:41 PM
01 XLT Sport's Avatar
You really can’t beat a Motorcraft filter, as far as Fram goes and what I have read about it I would only use a Fram filter on my X wife’s car if a court forced me to change her oil…
Old Apr 7, 2004 | 01:48 PM
TXSVTLIGHTNING's Avatar
Can't beat the Motorcraft FL-820S (pretty sure thats the one)
Every WalMart carries them so should be easy to find, along with the 5W-20 for those with '01-up who are using it for the 1st few changes.
Old Apr 7, 2004 | 01:53 PM
lifeguardjoe's Avatar
Whats wrong with Fram?
Old Apr 7, 2004 | 02:25 PM
topsy's Avatar
They have a really bad rep. There's a few other bad ones out there too, so at least go with the Motorcraft since it's not very expensive and readily available.
Old Apr 7, 2004 | 03:05 PM
grinomyte's Avatar
take a dry fram apart and it looks like a kids felt project inside. Crappy anti drain back valve as well. Overall just a bad filter, i've heard of two bursts that put filter element inside of the engine.
Old Apr 7, 2004 | 03:48 PM
superfords's Avatar
yep IMHO, the standard motorcraft FL-820 is a great filter for the money. available lots of places.
I use the Mobil 1 filter though. stronger case (burst pressure) and better filter material. pricey though. I believe it's part #210
later,
chris
Old Apr 7, 2004 | 03:52 PM
don presby's Avatar
Re: Oil Filter...
K&N part # 2010
Old Apr 7, 2004 | 07:23 PM
moses Black 01''s Avatar
Also wix is a good one. We use them on all of our company equipment. Cut one open and see what you think
Old Apr 7, 2004 | 08:00 PM
max mitchell's Avatar
Mobil 1 and K&N used here....better in many aspects including higher filtration synthetic media. Fram is a POS with a cardboard anti-drainback valve. If you can't afford $10-$12 for a better filter, buy the Motorcraft. Oil filters are like condoms....not the place to cut corners.
Old Apr 7, 2004 | 09:11 PM
Twisted99's Avatar
I pay under 10 bucks at Discount Autoparts for the k&N Gold.
Old Apr 7, 2004 | 09:45 PM
Robert Francis's Avatar
Many years ago I also cut several different types of oil filters apart. Of all I cut apart - ony 2 really stood out as really different from the rest; AC Delco whch had much more filtering paper than any of the others - and the Fram - which still had the string around the middle and some flimsy paper on it's ends - just looked like real POC. I've never used a Fram since.
Old Apr 7, 2004 | 10:57 PM
99 SVT Bolt's Avatar
Hmmm now only if I could find that site where they showed you the results after they cut open various filters. The motorcraft filter is a very good filter.
Old Apr 7, 2004 | 11:21 PM
sid297's Avatar
Here you go:
http://minimopar.knizefamily.net/oilfilterstudy.html
Old Apr 7, 2004 | 11:22 PM
SuperCrew02's Avatar
Heres another...
http://people.msoe.edu/~yoderw/oilfi...ilfilters.html
