Heat Exchanger w/ fans and Efan
What are yalls opinions abou the aftermarket Heta Exchangers with dual Spal Fans, and the E-fan?
What are the benefits of these 2 mods?
Thanks,
Simon
Thanks,
Simon
The Spal fans and aftermarket heat exchanger helps remove the excessive heat produced that comes from overspinning the crap out of the Eaton.
Once you have the stock clutch fan fan in your hand, you will realize, that removing all that weight off the front of the motor, is a good thing.
GO GATORS
GO GATORS
GO GATORS
Originally posted by TampaBlack99
If your gonna do both, i would upgrade the alternator.
I had 2 SPAL's on my HE, the main fan, the IC pump, and a powercooler all running with the stock battery and alternator.
Was I just lucky to not have problems
--Joe
Originally posted by whitebolt01
Thanks guys for the replies keep them comin
Gator, almost forgot
War Eagle
Thanks,
Simon
War Eagle
Thanks,
Simon
I saw your location, so I had to add.....
Go Gators
Guess I've been lucky with my stock electrial system also, now the stock fuel system is another story
