Question about EFAN
Old Apr 6, 2004 | 06:49 PM
scott015's Avatar
Question about EFAN
i think im gonna do efan next... i remember reading somewhere that people make their own homemade ones or even use ones that werent specially made for f150 lightnings....
other than buying a $500 one online... does anyone have any other alternatives??? i was considering making my own but needed instructions
or would any of these work??
http://search.ebay.com/ws/search/Sal...sortproperty=3
Old Apr 6, 2004 | 07:25 PM
tommylightning's Avatar
Check out our kits. They are a great setup and very easy to install. I have removed and installed others and can tell you first hand that ours is the easiest to install and by far the best fan out there.
It is for sale for $399.95 or with the Cobra water pump for $459.95
Link to them on our website:
Electric Fan Kits
Old Apr 6, 2004 | 07:38 PM
moses Black 01''s Avatar
Any fan setup for a 97-03 f150 will work. The only thing you have to build is an intercooler bracket. You can also use a stock efan off of a mustang. Just cut the shroud off of it and mount it to the stock lightning shroud using some 90degree strips of metal. Then all you have to do is just wire it up. Either way you have to do a little bit of fabrication. Its really not that bad of a job for the money you save. Good Luck
Old Apr 6, 2004 | 07:40 PM
grinomyte's Avatar
This is just hearsay but I believe the crown vics will also work, or at least the police crown vics have an efan that nearly bolts right up as well. Since they are the same engine i imagine it's true. Police crusiers crash all the time, might find one in salvage.
Old Apr 6, 2004 | 07:45 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
Check out https://www.f150online.com/forums/sh...&highlight=fan
All the info you could need to build your own e-fan.
Bob
Old Apr 6, 2004 | 07:48 PM
Using the mustang efan isn't hearsay because ive done it.
The link youve posted is a very good outline of how ot do it
Old Apr 6, 2004 | 07:56 PM
grinomyte's Avatar
oh i didnt mean the mustang one was hearsay, i meant the crown vic one was hearsay, i haven't done it, nor checked it out. Yeah i worded that odd, i'll edit it sorry.
Old Apr 6, 2004 | 08:41 PM
s.cal L 2's Avatar
I did my own for $80, works perfectly even in 110 heat. Took it off a 96 t-bird with the 4.6. Hooked up on High with a toggle switch and a monster fuse. No problems at all.
Old Apr 6, 2004 | 08:46 PM
jimkalfakis's Avatar
Crown Vic Police Intercepters don`t have E-fans.
Old Apr 7, 2004 | 08:47 AM
brain bypass's Avatar
i used the Motorcraft RF-86 18" Curved Blade, 2 speed, Electric Fan. yes it moves plenty of air. i got mine from rockauto.com for $135. paid $85 for the MAD enterprise wiring kit. done. out the door just over $200. never runs over 185 even when it was in the 90 the other day down here. no overide switch, but in the instructions, it tells you how to wire one in. not a big deal to do. i got the kit for mad enterprise:
http://www.madenterprise.com/F150.htm
and the fan from:
www.rockauto.com
you will probably have to get the pigtail for the fan from MAD, but it is only $10. just go to rockauto and search for part number rf-86 to find the fan. all you have to make is the brackets to hold the fan in. i made some out of some 0.5" flat steel bar i got from home depot. i have pictures of my fabrication and installation of you want to see.
Old Apr 7, 2004 | 01:28 PM
echo5oscar's Avatar
Does anyone use Hayden fans or electric fan controllers? They have an adjustable controller that is adjustable from 160-230. Like many have said before I dont see how they(the vendors) can justify charging so much for some thing that is so inexpensive to produce. I guess you can find suckers to buy just about anything.
Old Apr 7, 2004 | 01:46 PM
l-menace's Avatar
ttt... also want to know about the hayden adjustable wiring kit.
the one I have simply has a thermometer that slides inbetween the coils inthe radiator.
I would really like something more precise.
Ech05star,
do you have a link or something for this kit?
Old Apr 7, 2004 | 01:51 PM
l-menace's Avatar
http://www.derale.com/electricfanaccess.shtml
this?
Old Apr 7, 2004 | 03:29 PM
Pumphead's Avatar
Scott015
Do a search with E*Fan like Chainsaw13 did. You will find all kinds of information. I originally purchased a fan kit and did not like the way it was controlled. When it was all said and done the Ford fan, a Painless temp sender, a couple of relays, 2 fuse blocks, a 160 degree thermostat, and some wire is all you need to make an E Fan that works GREAT! The wiring information is all there you just have to look.
Old Apr 7, 2004 | 04:01 PM
Dan_03Lightning's Avatar
I bought Tom's at Outrageous, spent less than $400 and that was installed - very happy with the installation and fan.
D-Day
