Do 01 wheels work on 99's?
Old Apr 6, 2004 | 02:18 AM
player19's Avatar
I bought some 01 wheels to mount on my 99--- but while buying some extra lugnuts, the parts guys said that it isn't a good idea because they will move around while mounted... I know that the 01's have different lugs...
I remember reading awhile ago that 99 wheels can't be mounted on 01+ --- but never the other way around.... So should I not mount them ?
Old Apr 6, 2004 | 09:36 AM
ShadowBolt's Avatar
The 99 wheels CAN be used on any year Gen 2 (I have them on my 03). The later years (01 and after) have larger lug holes and I don't think I would try going that way.
Jerry
Old Apr 6, 2004 | 09:38 AM
LatemodelRacer2's Avatar
99 have 12mm studs
00 and up have 14mm
Old Apr 6, 2004 | 09:54 AM
RDY2RAC's Avatar
Jerry
are you sure you dont have 00 wheels??? which use a 14mm lugnut.
Old Apr 6, 2004 | 10:02 AM
ShadowBolt's Avatar
Yes I'm sure they are 99's. The wheel will just fit over the lugs. It is tight but it WILL fit.
Jerry
Old Apr 6, 2004 | 11:12 AM
easterisland's Avatar
My father has my old chromed 2001 wheels on his 1999 Lightning.
Old Apr 6, 2004 | 11:18 AM
TXSVTLIGHTNING's Avatar
the 99's have 12mm lugs so the hole is smaller.
(won't fit 2000-2004 which have 14mm lugs unless you enlarge the holes)
The 2000-2004 wheels will fit the '99s
Old Apr 6, 2004 | 11:53 AM
PhillipSVT's Avatar
I have 02 wheels on a 99.
Old May 10, 2005 | 12:32 PM
halcyon's Avatar
So that's like 2-no's, 3 yes's, and a few maybes.........
Is there any definate answer on this before I drop a bunch of money on chrome 01-02 wheels for my 99?
Thanks.........
Old May 10, 2005 | 02:03 PM
ZorPrime's Avatar
theyll fit.
Old May 10, 2005 | 04:31 PM
kerno's Avatar
Your 1999 studs are 12 mm and the later ones are 14 mm. As such, the holes in the later wheels are about 2 mm larger. In every case, the holes in the wheels have clearance for the studs - none of them are a press fit or even close. There have been a lot of people who have put later wheels on early trucks and I have never read a post which said anyone had a problem. The hub locates the wheel and fits fairly tight, but that diameter is the same on all of them. The studs limit the rotation of the wheels on the hub, but as long as they are tight, everything appears to work just fine.
Old May 10, 2005 | 05:15 PM
halcyon's Avatar
good deal, that's what I thought.....
anyone selling a set of chrome 01-02 rims
I'm going to try an go used, but may end up at replicawheels.com
Can i use the same lugs?
Old May 10, 2005 | 05:33 PM
nathan211's Avatar
good luck finding 01 chrome wheels!! i ordered 20" replicas from lake shore wheel which was the only place i could find that said they could get them. this was over 2 months ago they are on back order from the factory and they wont give me a straight answer as to when theyll be done.
Old May 11, 2005 | 10:02 AM
Blown347Hatch's Avatar
I was looking at your sig with the centrifugal. Have you been to the track yet? What kind of trap speed are you getting?
Old Apr 5, 2008 | 02:29 PM
Fx4OffRd's Avatar
Hey guys, sorry this is a little different question...but will 2005 F150 wheels fit on a 1998 F150?
