4# with stock tune, and dyno to check a/f
Old Apr 5, 2004 | 07:15 PM
2004_az_L's Avatar
is it safe to say that if i installed a 4# pulley on my stock 04L and put it on a dyno and found out the a/f was fine i would be ok and not have to worry about blowing it up. I only have enough money for a 4# and nothing else like a predator. What does everyone think. I went to the track and ran a 13.76. i wanna run low 13's. I also want to be able to take the mods off if something happens and be able to receive warranty work. is it possible to get low 13's without a chip? thanx everyone.
Old Apr 5, 2004 | 08:13 PM
LOCOSVT's Avatar
How many miles do you have on it? The performance will pick up as you get a few K miles on it.
A cheap reversible mod is to remove the lower airbox, and ziptie the filter to the top.
Old Apr 5, 2004 | 09:27 PM
TiresWinRaces's Avatar
You might be OK, but it depends what plugs you are running. Even if your A/F's are at 12.0 or under, that doesn't mean you aren't making a hot spark and burn with the stock plugs.
Go with NGK TR-6's (colder than stock) to be safe. Very cheap insurance, under $3 each to save your motor.
Also, without a performance tune, you aren't getting the added benefit of some additional timing.
Old Apr 5, 2004 | 11:50 PM
grinomyte's Avatar
save up til you can get the pulley and a proper tune.
