dnloading Pred files to DAT software
Can't do it!
I loaded the program for Viewing Logged data...It seems to have loaded properly.
I connect the P through the Com Port, set all baud settings the same, and try loading the Log file into the program.
Windows aborts the communication about 5 sec after communication begins.
Does this sound farmiliar to anyone? I could really use some help
Originally posted by denny0328
Try this (thaks to lightstruck)
CMR-Dat...Tools....Get Log File from Predator
Predator....Options.....Troubleshooting....Log Upload
-dennis
-dennis
Aaron
where did you get the software to view the log at? Also, what is the name of the software. I would like to get it so I can view my data.
Also, is there any special software needed to upload/download tunes from pc to predator and vise versa?
Chris
Chris
http://www.yonsonracing.com/dat.html
i believe this is it. Scroll down to #4 Dat Viewer.
Thanks for the mention denny---glad I was actually able to help someone!!!
The only problem I have had is I can't seem to look at the logs unless the Peditor is hooked up I down loaded them but when I look at them without the Preditor hooked up all I get is a bunch of giberish unassigned stuff do you have to view it with the preditor hooked to the laptop?
jeff
jeff
-dennis
Well when I look at mine the numerical chart says unassigned and the graph is just about a inch wide and the other peramiters just zig zag back and forth. Just giberish even the sample does it now but it will read right when I have it hooked up to the Preditor.
I run the log then download it to my lop top run it with the preditor works great disconnect the preditor ran it again worked great shut the loptop down pulled it back up in a couple of days and bam not in master pid list.
jeff
jeff
Let me know how it goes...
I think that when I shut down my safotware and started it back up again it didn't automaticly load the file back in there, I had to open it up from where I saved it the first time when I originaly got it off the predator. Hope you get it...
-dennis
-dennis
