Can Anyone Help Quick Q!!
Old Apr 3, 2004 | 10:22 PM
vegaslightning's Avatar
My intercooler got smashed by a rock on the freeway last night and destroyed the connection to the hose, so i figure i get an aftermarket intercooler since the dealer wants 600 for the stock pos. So does anyone have any suggestions to a new intercooler? where i might get one with fast shipping.. and also any tips on installing? it seems rather simple..unbolt the old, install the new, add the correct fluid/water and good to go?
thank you!!!
Old Apr 3, 2004 | 10:24 PM
AMP's Avatar
AMP
try this
Johnny Lightning Performance
$429
Is this what you're looking for?
Old Apr 3, 2004 | 10:27 PM
its this part, under the bottom grill on the front bumper this is the view from underneath looking behind the cooler..http://www.truckinweb.com/tech/0310t...cooler05_z.jpg
Old Apr 3, 2004 | 10:29 PM
AMP's Avatar
AMP
yeah, that's your heat exchanger. Your intercooler is under your blower. If the exchanger is bad and dealer wants 600, I'd order the bigger one from JLP for 429. (do the math )
Old Apr 3, 2004 | 10:32 PM
allright thank you so much, even the dealer didnt know what it was i told them the same thing ive told you as far as parts and they said it was the intercooler, so if they are qouting me on a wrong part and price then i should find out how much the heat exchanger will be stock? and if its around the same then just got the aftermarket...can you tell me where i can order that cooler you showed me? and is that the best for the buck? or do you have any other suggestions>...thank you so much for the help guys!!!!
Old Apr 3, 2004 | 10:36 PM
AMP's Avatar
AMP
johnnylightningperf.com
Old Apr 3, 2004 | 10:40 PM
Don's Bolt's Avatar
Or JDM, who was the first one to come out with a heat exchanger for our trucks.
www.teamjdm.com
and since Johnny is in Georgia right now, you might be able to get it faster from JDM
Old Apr 3, 2004 | 10:41 PM
thanks alot you guys, now im gunna prob be doing this install, anyone have any tips? im guessing its easy bolt off bolt on ??
