Wheel Noise
Old Apr 3, 2004 | 06:25 PM
Dman25's Avatar
Wheel Noise
As i was driving today i started to hear a scratching noise, so i got out of the car and had my friend drive it and i walked with it, it sounds like a light metal scratching noise coming from the passenger front wheel, any suggestions what this could be? thanks guys.
Old Apr 3, 2004 | 06:49 PM
TriPodRacing's Avatar
Time for some brakes.Or you have a rock stuck in there somewhere.
Old Apr 3, 2004 | 07:16 PM
Dman25's Avatar
well the thing is the sound is being made even when the brakes are not being applied, ill try to take the wheel off tommorow and check it out, problem is i only have a few hand tools and the jack thats in the truck.
Old Apr 4, 2004 | 01:38 AM
Dman25's Avatar
ttt
Old Apr 4, 2004 | 01:52 AM
grinomyte's Avatar
jack up the truck and turn the wheel. The brake is always in contact with the rotor, so maybe you did get a rock stuck in between there somewhere and its grinding as you drive around.
Once you have it jacked up you should be able to locate the sound much easier.
Killa B's Avatar
I had a similar problem a year or so ago on my old cobra - It turned out I had a small rock stuck between the brake pad and the disc.
Old Apr 4, 2004 | 08:24 PM
Dman25's Avatar
i took off the wheel, my inner brake pad is worn out, ive never totally changed brakes by myself, but could someone please tell me what i might need to do it. My dad wont let my take them in to be replaced because he says he can fix it him self, but im 200 miles away from home so i gotta do it on my own. My inner rotor is a bit worn also, do u think i could just run with the new pads until i get home in june.
Also, what brake pads should i get, i can only buy them from Kragen, on store in town and they cant be that expesive or my dad will go ape *****.
Old Apr 4, 2004 | 08:59 PM
Don's Bolt's Avatar
What do you mean by a bit worn, are there gouges in the rotor.
You may be able to just replace the pads, but without seeing the rotor it is hard to tell.
What you have to do is remove the two bolts that hold the caliper to the spindle, remove the pads, and then take a big C clamp and push the piston into the caliper. Then replace the pads and reinstall the caliper.
if you go to
http://www.svtlightnings.com/
go to how to articles and look for front brake pad how to. It will give you all the info you need.
Old Apr 4, 2004 | 10:33 PM
Dman25's Avatar
do i need that star tool to take off tha calipers, or can i take it off by taking off the bigger bolts? Also the discs are worn about 1/4 of the disc. the grooves arent that deep, so maybe i can just have them turned later.
Old Apr 4, 2004 | 10:34 PM
grinomyte's Avatar
and don't let the calipur hang by the hose, use a coat hanger to dangle it from the a arm or somewhere.
Old Apr 4, 2004 | 11:15 PM
porsen's Avatar
-and when you apply the C-clamp to push the piston back, don't turn it to fast. Nice and slow and give the brake fluid time to return to the container.
I turned it to fast once and the container overflowed even though I had not added brake fluid.
Old Apr 4, 2004 | 11:20 PM
Don's Bolt's Avatar
Ya you have to remove the T 45 torx bolt
Old Apr 4, 2004 | 11:37 PM
Dman25's Avatar
thanks a lot guys, ill see what i can do with all this great info
Old Apr 5, 2004 | 12:02 AM
LatemodelRacer2's Avatar
How long should i expect my stock pads to last?
Old Apr 5, 2004 | 02:16 AM
Dman25's Avatar
so u know, im at 35000
