uh...is it bad when this happens???
Old Apr 2, 2004 | 10:07 PM
superfords's Avatar
hi guys, well I pretty much knew that I had hurt my plugs last week when I sprayed the truck at the track. it was detonating, but it was going so fast that I didn't want to lift.
going by the 1/8 mile time (7.27@94mph), I figure I would've run about an 11.30 or so in the quarter mile.
however, the truck lost power and I had to shut it down at half track, resulting in a 11.85 at a whopping 92mph.
anyway, here's the picture.
this is what happens when you know you should lift, but dont:
two IT-22s up in smoke. one melted the electrode off and destroyed the porcelain, the other just destroyed the porcelain starting at the bottom! the very tip of the porcelain is just jingling around on the center electrode like a little hoola hoop or something!
oh well, thank goodness it wasn't worse (a piston or ring) I swapped the old plugs out for some NGK BR7s tonight after work.
I hope to get the truck on the dyno tomorrow and try the nitrous again to find out what the problem is. I don't think it's a lean condition, and I kinda doubt it's too much timing, it may just be an octane issue, but I'll find out soon enough.
later,
chris
Old Apr 2, 2004 | 10:42 PM
whip's Avatar
Hope everything goes allright, and take it easy on that ol girl until you get some decent times out of it!
Old Apr 2, 2004 | 11:06 PM
Suavy's Avatar
be strong my brother.
Old Apr 2, 2004 | 11:42 PM
D Davis's Avatar
Glad you didn't hurt anything else, after all the work on it this winter. Thought you did something bad when I read the title.
Good luck at the dyno
Old Apr 3, 2004 | 01:45 AM
grinomyte's Avatar
not bothering to break it in i take it
Old Apr 3, 2004 | 08:04 AM
Rob_02Lightning's Avatar
Ahh thats Nothing Chris
What are BR7's gonna do that IT-22's dont ???
That would have happen with BR-7's too,
That problems in your fuel system or tune, "NOT THE PLUGS"
I KNOW you'll figure it out, TG thats all that happen
GOOD LUCK BRO
Old Apr 3, 2004 | 08:15 AM
Blown93's Avatar
Hope you get it right Chris, and you will.. Sure happy for you it was not something more costly man......... I'm anxious to see that motor in one piece.............
PEacE................
Old Apr 3, 2004 | 08:55 AM
Fast Gator's Avatar
easy there Chris...........
don't hurt that beautiful gal till you take care of ole Fordtek
BTW....too much timing =
Old Apr 3, 2004 | 12:34 PM
clonetek's Avatar
don't you guys wonder where the stuff that breaks off goes to?
could it have chewed up a valve? could it be rattling around in the cylinder?
Old Apr 3, 2004 | 02:10 PM
superfords's Avatar
while I've never actually spent any time INSIDE a combustion chamber while an engine was running...
I don't think that it just breaks off in one piece.
think of a fuse blowing from too much current, the metal wire actually melts very quickly.
detonation is the uncontrolled burning of fuel in the combustion chamber. "uncontrolled" because the fuel is actually igniting BEFORE the spark is fired by the coil/distributor/plug etc. the fuel burns on its own because of the EXTREME TEMPERATURES created by boost, nitrous, compression, lean air fuel, etc. I'm guessing it must be what between 1000 and 2000 degrees in there? hot enough for the fuel to just EXPLODE on it's own. I'd say that's hot enough to melt that little tiny side electrode. maybe somebody with more knowledge in this area will chime in, because I'm certainly not an expert. and maybe I'm not 100% correct here.
but anyway, I believe that it melts or burns off. at least the electrode does.
the porcelain, I don't know.
either way, it would blow out the exhaust valve.
if there were any actual chunks, they are prolly stuck in the front of my catalytic converter right now!
BTW, I had a friend that worked as a mechanic in the army. he once told me about working on the HUMVEE diesel engines. he said that they often broke the glow plugs off in the head. frequently they couldn't be removed for some reason, so they just beat the crap out of them until the pieces fell down in the cylinder then installed a new plug and fired it up and let the pieces blow out of the exhaust valve!
sounds crazy to me, especially on a diesel with such high compression, on many diesels the piston actually comes up out of the block into the combustion chamber a little. wouldn't leave much room for spare parts. but anyway, that's what he said they did.
later,
chris
Old Apr 3, 2004 | 05:35 PM
Justin@JDM's Avatar
Banned
It could chip an exhaust valve on the way out.
Old Apr 4, 2004 | 10:32 PM
Jay Lincoln's Avatar
The porcelin won't melt. Hopefully it found it's way out before it got under an exahust valve.
The BR7 is much colder and is not a projected gap plug, so it will have a tendency to live as little longer, It will not fix the detonation that broke the porcelin. That's a function of the timing and or air/fuel ratio.
Hope there was no damage.
