Ford Service Sucks!
Ford Service Sucks!
Did you sign any paperwork when you dropped the truck off? If so, there is a chance that the fine writting at the bottom expresses your consent and agreement to pay for work deemed necessary. I've seen this before and it is BS.
Re: Ford Service Sucks!
Originally posted by SlammedSVT
http://www.svtperformance.com/forums...threadid=89713
I am going to tell them that I am going to pay the agreeded 29.95. I hope they give in and if they dont, I guess more hell will be raised.
Originally posted by Fear Itself
While they shouldn't have done any authorized work, noone will be able to align it without a cam bolt kit if it is lowered.
you cannot be held responsible to pay for work that you did not authorize.
however, it's not like they overhauled your transmission. they did the work that was required to align your truck. you were far from being under warranty, it had nothing to do with your lowering kit. alignment can only be done once under warranty and it has to be under 12 months/12thousand miles.
prolly what happened was, the alignment guy went to the service writer and said, I checked the alignment, it's out of spec, and because it's been lowered, I don't have enough room to adjust it. it needs camber adjusters. the service writer said ok, figuring that it'd be ok because you came in asking for the alignment in the first place and these parts and labor were required to properly perform that repair.
that was his mistake, not yours, he/she should have called you for approval, not just "assumed" that it was ok with you.
so on that technicality you shouldn't pay for the work/labor.
however, that doesn't mean that they overcharged you or performed un-needed repairs on your vehicle.
Ford service doesn't suck, they just made a stupid assumption/decision.
you on the other hand made a stupid assumption that even after lowering your truck the only thing you'd need was a 29 dollar alignment.
just my .02
later,
chris
just my .02
later,
chris
just my .02
later,
chris
You do have some good points though.
sorry about that slammedSVT, I was in a bad mood last night.
you aren't stupid. I was rude. the last comment was uncalled for.
my apologies.
I hope you get the situation resolved to your satisfaction.
later,
chris
my apologies.
later,
chris
my apologies.
later,
chris
my apologies.
later,
chris
Its alright man. I was wrong one some of the things I said. I was just pissed as well last night.
