oil TEMP sensor location?
Old Mar 30, 2004 | 07:56 PM
007IGHTNING's Avatar
Im going to be installing my tri-pillar pod this weekend. I have the Autometer 'Lunar Series' Fuel Pressure gauge, Boost gauge, and a Temp gauge. (with a flip of a 3-on switch it will tell me the temp for my Water, Trans, and Oil. I have all of the other sensors screwed into place except the OIL TEMP. Where is the location for the OIL TEMP sensor.
The reason I type in bold for OIL TEMP is because, while doing a search (to no avail) someone else was asking the same question and was getting helpful responses for oil pressure.
If you have any pics of the OIL TEMP sensor location, that would be very helpful.
John
Old Mar 30, 2004 | 08:19 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
do a quick search under my name and you'll uncover all the necessary hardware to install the oil temp sender. (less one 90' elbow that is)
The location for the hardware is where the stock oil pressure sending unit attaches to the block. Lower left front side.
Hope this helps.
Bob
Old Mar 30, 2004 | 09:51 PM
Awsome, thanks SpeedinBob. Pictures tell a thousand words-or something like that.
John
Old Mar 31, 2004 | 03:40 PM
no problemo.
Glad to help.
