Part Numbers for Build-up
Old Mar 30, 2004 | 11:08 AM
TampaBlack99's Avatar
Here are a bunch of part numbers, hopefully they will be of help to a few people.
Upper Plenum XL3V-9A589-AA
EGR Valve XL3E-9D475-C3A
EGR Tube XL3Z-9D477-CA
Steps
(R) F65B-83200L88-ADW
(L) F65B-83200L94-ADW
Caps
(R) F65B-8313090-AGW
(L) F65B-8313091-AGW
Bed Caps
(R) F65Z-83291A40-AAA
(L) F65Z-83291A41-AAA
AC Compressor F758-19D-629-BA
Intercooler Pump F7LZ-19703-AA
Front Ford Emblem F81B-8B262-AA
Back Ford Emblem F85B-8C026-AA
Fender Emblems XL3Z-16720-AA
Tailgate SVT Emblem XL3Z- 8342528-AA
Slider Window Shroud F85B-15423 A00
SideView Mirror F65B-17K707-EA
Clarion CD Changer Cartridge (this is a clarion part #, not a Ford #)
CAA-355-601
Chrome Navigator Antenna Base F85Z-18A927-AA
Front Shock Rubber Donut F75A-5415-2A
Ball Hitch Cover XL3Z-17D754-AAB
Front Bumper Cover 1L3Z-17D957-BB
Upper/Lower Manifold 9424
Upper Manifold Gasket 9H486
Lower Manifold Gasket 9461
SuperCharger 6F066
Aluminum Driveshaft 1L3Z4602BA
3.73 Gears 3L1Z4209DB
03 Satin Door Handles
XL34-1521819-AA
XL34-1521818-AA 50
Old Mar 30, 2004 | 11:14 AM
BOLTS
Throttle Body
(2) ?
(2) N808429-S309
Plenum (TB Spacer)
(5) N808429-S309
(1) Long Bolt ?
a) 89 Lb-In Soft Metal
b) 90˚ Turn
IAC (2) N808429-S309
S/C Nose Bolts (8)
20 Lb-Ft
SuperCharger Bolts
(4) W705653-S309
(4) N606571-S309
a) 18 Lb-In Use Once
b) 33 Lb-Ft
Intercooler
(9) N606500-S100
53 Lb-In
Mid-Plate
(2) 6A008
(4) N605922-S309
Manifold
(2) 6A008
(9) N806156-S301
(tighten in a zig zag pattern) Use Judgement
Radiator Hose Fitting on Manifold
(2) N806178-S309
GASKETS
Throttle Body to Plenum
F81Z-9E936-AA
Plenum to Blower
XL3Z-9L437-CA
SuperCharger to Mid-Plate (Metal)
9H486
Mid-Plate to Manifold
9461
Gasket for Intercooler
9M436
Pulleys (Torq Specs)
Idler Pulley 18-24 Lb-Ft
Auxiliary Crankshaft Pulley 74 Lb -Ft
Pulley Cage 35 Lb-Ft
Metco Pulley 35 Lb-Ft
Metco Hub 25 Lb-Ft
Old Mar 30, 2004 | 11:51 AM
VINNIE's Avatar
Excellent posts.
Should make it a Sticky
