Temp Guage Hook-up Question
Old Mar 28, 2004 | 09:48 PM
TheYak's Avatar
I have an AutoMeter temp guage and am confused on how to hook it up. Can i just tap off the original Hot/Cold guages' temp sender wire? If so where is it? If not, where do i install the autometer temp sender? And how do i find the ignition switch wire? I'd sure appreciate some help! Thanks in advance
Old Mar 28, 2004 | 09:50 PM
MISTERgadget's Avatar
Trannny, water or oil temp?
Old Mar 28, 2004 | 10:26 PM
Stl01SVT's Avatar
If you are talking about a coolant temp guage. There is a block drain plug on the lower left side of the engine you can remove and install the sensor. Or if that sight is being used like mine, with an e. fan temp sensor. You can drill and tap the thermostat housing.
Old Mar 28, 2004 | 10:27 PM
TheYak's Avatar
Water... (i can't believe i left that part out)
B-Man's Avatar
Cool
I assume you are referring to a water temp gauge. You will need to install the sending unit that came with the gauge.
You can get ignition power from a multitude of sources. I like to use one of the open relay sockets in the underhood fuse/relay box. Keeps from splicing wires and/or using fuse taps, but that is just me.
Old Mar 28, 2004 | 10:30 PM
TheYak's Avatar
What about the ignition switch wire? Where and how do i tap into it? Is there no way to tap off the original dash H/C guage?
Old Mar 28, 2004 | 10:39 PM
TheYak's Avatar
Thanks alot guys
Old Mar 29, 2004 | 05:40 PM
TheYak's Avatar
Looked for the drain plug today... left meaning driver's side of passenger side? I couldn't find it but i'm sure it's there. "lil help"
Old Mar 29, 2004 | 06:01 PM
bigdaddy's L's Avatar
Driver side above the oil filter, right by the freeze out plug.
