Cleaning the engine?
Old Mar 20, 2004 | 09:33 AM
LightningToGo's Avatar
What should I be careful not to get wet while spraying the engine with the water hose and why?
Old Mar 20, 2004 | 10:06 AM
ZorPrime's Avatar
if you have an open air filter try and keep it dry
soak the rest of the engine. been doin it for years. no issues
i suggest not using high pressure.
Old Mar 20, 2004 | 10:07 AM
scott015's Avatar
ya dont get the airbox wet, maybe even throw a small towel over it.... other than that... i just spray it all down, but try not to drench the battery.....
Old Mar 20, 2004 | 02:19 PM
EZGZ's Avatar
I would keep it away from the spark plug holes and coil packs.
I also used compressed air to blow things dry and then warm the engine to finish the job.
Then start my detailing after all that.
Don't forget to wax the underside of the hood
Old Mar 20, 2004 | 02:39 PM
kobiashi's Avatar
NO !!!!!!!!!!!!!
Don't spray it with a hose......
Don't get it wet.......
My detailer HAND CLEANS engines...no water...he cleans up every nook and cranney by hand....
Looks awesome....
See if you can find someone where you are who does this.
Here's my first L after detailing (sorry, the pic is a bit blurry)
Old Mar 20, 2004 | 03:03 PM
ZorPrime's Avatar
so how much your detailer charge you to 'hand" clean the engine compartment?
Old Mar 20, 2004 | 03:48 PM
kobiashi's Avatar
Beats me, it's part of the overall detailing package.
To have the entire truck detailed, interior, exterior (including bed), engine, was 250.
