Help with Fast Air question
Old Mar 13, 2004 | 11:16 AM
ShadowBolt's Avatar
I bought mine used and got no instructions. Obviously this is not going to be hard to do but where does the air hose that connects to the end of the air box go? Does it go through the hole in the fender? If so do you have to remove the inner fender well to install the hose? It does not look like there is any other way.
Jerry
Old Mar 13, 2004 | 11:30 AM
RhinoSlug's Avatar
You run it through the hole in the engine compartment and run it down to the scoop. You will have to cut the wheel well liner and zip tie the air hose along the fender.
Old Mar 13, 2004 | 11:35 AM
ShadowBolt's Avatar
Thanks for the info but that sucks! I may just run a small hose to the fender well (like the stock box does) and run the other hose to the air scoop. I may even buy a single air scoop and sell the PSP one. I would think the air coming from the opening in the fender well and one hose from a scoop below the air dam would work quite well.
Jerry
