Ported eaton (WASPII) is on....
Old Mar 13, 2004 | 10:02 AM
0light1's Avatar
Got it on last night. Overall it really was an easy job.
1st thing, Wes does very good work. It looks factory to me.
In 40deg weather I am getting 15#'s of boost max @ around 80-90mph. Now, I could get that in 20-30 deg weather but it would slowly work it's way there. Now it hits 14#'s almost instantly then quickly moves to 15#. If I just tap the pedal it hits 10#.
I'm not sure I can say I feel this major difference like I did when I put my first chip in or pulley. I can say for sure it's not worse at all.
I am going to the track in a few hours then I will truly know the results.
*Note:
My TPS voltage was at .93 (I set it back to .99) and I had to reset my chip (pulled the pos. bat. cable) I think I heard detonation for the first time. It was like a fast faint flutter, got of it instantly. Also, my shift were soft and i knew something was wrong. Yes, I have line pressure upped just a little.
Also I can see where it would be very easy when putting the throttle body back on to get the cables crossed. There is a littel groove under the main plastic piece that holds the cables. The top one goes under and in the groove back pout the front. I had them crossed at first, Took me about 15min. to figure this out.
I'll let you all know the track results.
Old Mar 13, 2004 | 10:13 AM
scott015's Avatar
see now im discouraged.... yours and my eatons where getting done by wes at the exact same time and he shipped them both out monday...
i got mine on and i do not notice the difference right way, and my boost tops out at 12....
i dont know what to say except im gonna try and get dyno and reburn ????????????????????????????
