My Goals for my stock block
Here are my goals... im almost all the way there as is... but just curious if these seem like good goals and a nice setup.
I dont really want to build the block (well i do, but cant afford it)... so is this too much stress on a stock engine, or will I still be ok if taken care of??
HAVE:
4lb
90 Mass Air
PSP Chip
IT20 Plugs
Boost Bypass
JLP Ram Air
Traction Bars
High Flow Cats / Flowmaster Catback
Wes Ported Eaton
FTVB
Accufab Throttle Body (ordered, not in yet)
WANT:
160' Thermostat
EFan/Pump
Phelonic Spacer
Long Tubes
HAVE:
4lb
90 Mass Air
PSP Chip
IT20 Plugs
Boost Bypass
JLP Ram Air
Traction Bars
Wes Ported Eaton
FTVB
WANT:
160' Thermostat
EFan/Pump
Phelonic Spacer
Long Tubes
i've had a 10lb lower on my truck for the last year. stock block 2000. i think if you have a good tune and the supporting pieces you can get away with quit alot. i was putting down about 450 to the wheels.
Wow! That's amazing on a stock block. You my friend get a thumbs up
