Cam questions?
Old Mar 10, 2004 | 03:06 PM
lightning1291's Avatar
Cam questions?
hey all,
i am looking into putting cams in my new motor...
any suggestions on which ones?
i plan to have a 5 angle valve job done, but no real porting done (too much money)....
is it worth it to do cams with stock heads??
i have heard anywhere from 25RWHP to 65RWHP
i will most likely be going to a 6# pulley from a 4#
thanks in advance for the input!
Old Mar 10, 2004 | 07:51 PM
cpeapea's Avatar
are you going strickly race? if not then a 3 angle is about as much as you want to go on street
Old Mar 10, 2004 | 07:55 PM
Hilander's Avatar
What cpeapea said.
Old Mar 10, 2004 | 08:02 PM
thanks for the advice guys...
i also am thinking of adding an apten port to the mix...
what do you guys think about the apten port, 3 angle valve job, and stock head combo??
Old Mar 11, 2004 | 08:15 AM
bump^
Old Mar 11, 2004 | 12:52 PM
cams must be a black magic secret, or something.... i thought with all of the knowledge at this site, there would be more of a response
maybe a better question would be:
What to you guys do for a living? or maybe, How old are you?
Old Mar 11, 2004 | 01:17 PM
99SVT's Avatar
Try the Comp Cams #102600 cam. Good performance and still streetable. Will give you a little lope also... always a plus
Old Mar 11, 2004 | 01:32 PM
Dale-01L's Avatar
Ive got Crower Stage-2 (ish) cams in my truck.
When I went from my stock motor to my built motor I picked up about 40hp and 30ft/lbs.
Before - 466hp / 605tq
After - 505hp / 630tq
Only thing changed was the motor with mild hand-ported heads, big valves & the cams..
They give the motor a little bit of a lopey sound (nothing too drastic). Just enough to know they are there, which is cool.
Theres a sound clip of the idle >HERE< and >HERE<
-Dale
Old Mar 11, 2004 | 02:02 PM
99SVT and Dale-01L
thanks for the information
Old Mar 11, 2004 | 04:50 PM
JohnnyontheSpot's Avatar
Old Mar 11, 2004 | 08:40 PM
Originally posted by JohnnyontheSpot
Big John my nizzle
damn, i tried to post 2 images, and it tells me too many
guess thats too much fun
