Props to JLP and PSP!
Old Mar 8, 2004 | 07:00 PM
quickcanuck's Avatar
Thumbs up Props to JLP and PSP!
Ok, I have been peaking out a little tooooo quickly lately (ie. last night 's post re: broken 7mm coil pack....). At last today I see the sun shining!!
I received today 2 packages. First was the chip overnighted to me by John at JLP. Even though he was busy getting ready to go to Florida, he made time to burn another chip and get it across the country in 2 days!!! Plugged it in, and my truck is running great (as well as the high A/F reading, the idle was at 1100rpm) . The truck is idling fine now..the cams give a nice rock to it..!
Secondly, my FTVB from PSP came via FedEX.
Towed the truck to the body shop, and the Cervini hood actually FIT. Amazing for fiberglass hoods, but this actually fit, and will be done by Thursday.
Off to the dyno again with Wayne from Brown Brothers Ford on Friday to do it all again. I wish all you guys had the same SVT mechanics at your local Ford dealer. Who would have thought, a dealer getting into the aftermarket high performance ????
Cheers!
Old Mar 8, 2004 | 07:04 PM
Blown93's Avatar
I have one also that has a dyno and aftermarket chips etc....... But when they work on it you loose your warranty.........
PEacE...........
Old Mar 8, 2004 | 07:24 PM
LightningTuner's Avatar
You'll be even happier to know that I got your 60lb injectors in today, and right out to you, coming via Fed Intl Priority. Should be there in 2-3 days.
Old Mar 8, 2004 | 08:28 PM
Thanks Sal! I hope this will be the final step to get everything going. Thanks for your help. Look forward to doing more business with you.
Old Mar 8, 2004 | 09:23 PM
blown318's Avatar
sal, no florida???
Old Mar 9, 2004 | 09:25 PM
Wow! Just got my 60lb injectors from PSP. Got here in 2 days...over 4000 miles. Thanks Sal!
Old Mar 9, 2004 | 09:31 PM
JohnnyLightning's Avatar
quick, let me know how it goes with this chip..I would not install those 60# injectors until you check the A/F with what you have 1st.. you should have plenty of injector for your set-up.i'll check my e-mails for your results.......JL
Old Mar 9, 2004 | 11:32 PM
thehammer's Avatar
Re: Props to JLP and PSP!
Cheers!
looking forward to seeing you i will be there at 8am.
can't wait to see
