oil galley plugs?
Old Mar 8, 2004 | 05:57 PM
QUIKSVT's Avatar
oil galley plugs?
I have all new heads and short block. I did not pull the old plugs from the old heads. The new heads only came with 2 plugs. I know the rear passages need to be blocked, but what about the bottom front. I know the one needs to oil the timing chain tensioner. I think I'm short a couple of plugs. What size are these? Also need the plug for the water passage in the head, what size is that? Any help would be appreciated.
Thanks Josh
Old Mar 8, 2004 | 06:13 PM
dirtchicken's Avatar
I have some from my old motor. Shoot me an email with what you need exactly and your address to spaceboy383@yahoo.com and I'll send them to you.
Old Mar 8, 2004 | 08:05 PM
QUIKSVT's Avatar
Thanks Chicken, I just got a couple 1/8 pipe plugs from Jegs. I am going to get the other from the dealer.
Josh
Old Mar 8, 2004 | 08:33 PM
Glad you got it worked out.
Old Mar 8, 2004 | 08:48 PM
EZGZ's Avatar
From experience I remind you that if your using teflon tape for a pipe thread. DO NOT OVERTIGHTEN.
Pipe threads are tapered and the teflon is only there as a lubricant. The threads taper and tighten to seal themselves.
On steel to aluminum I prefer Pipe dope or locktight or antiseize. Even plain grease if you plan on removing it someday.
My .02
