largest wheels and tires
Old Mar 8, 2004 | 07:19 PM
Fast Gator's Avatar
Originally posted by Krix330cic(NJ)
You can go as larger as 24" if needed.. then again, who would be that stupid?
OR
put a cowl hood on a Ford
Old Mar 8, 2004 | 07:25 PM
Flord's Avatar
I have 22's..the overall wheel-tire height went from 28" to 31.5"
With stock suspension it looked silly to me (raised 1.75"). I installed a 2 / 2 drop and it looks/rides perfect. I only get a very slight rub when I hit really big bumps and I still haul heavy stuff regularly. I will say my stock bilstiens are shot..assuming due to the change in shock travel.
Don't be a sheep...get whatever YOU like.
Old Mar 8, 2004 | 11:50 PM
AmoJohnny's Avatar
My fav rims here has got to be Krix330cic(NJ). Thats just my opinion...it looks friggin PIMP. And again, its your opinion, do as you wish, bash me as you wish...I think it looks nice. Although it would probably slow ur truck down a bit, I think the pimp factor balances out the slower factor enough the justify buying them.
Old Mar 9, 2004 | 12:07 AM
denny0328's Avatar
I personally dont like anything bigger than 20's on a lightning, but those 24's on a harley look nice!! harleys are for Pimpin, so why not pimp?
and the black oz's look real nice too, honestly i think the black does make them look smaller, it kinda blends in with the rest of the truck...
Old Mar 9, 2004 | 12:26 AM
sporkdevil's Avatar
I'm running 305/45/22's on a F150. The only difference is the front of the L is one inch shorter. Rides great, won't rub on curbs or anything. I would perhaps go a bit smaller considering on a bad turn with a dip I did uh.... pop out that front plastic fenderwell cover. It does rub when turned all the way to either side. Considering that the 305/45 is a nice sized tire, you could go smaller and get a larger rim. I bet some 24's on a low pro tire would fit quite nicely. And beautifully.
Oh yes, twould be amazing. 22's would as well be amazing.
Old Mar 9, 2004 | 12:40 PM
BigBucBrew's Avatar
Those would actually be the OZ Vela III ST's, you can find them all over heres a quick search link http://www.autobahnx.com/o_z
Old Mar 9, 2004 | 12:52 PM
Krix330cic(NJ)'s Avatar
Thanks fellas!
Old Mar 9, 2004 | 03:46 PM
bacamino's Avatar
NOW that is Hott
the truck
Originally posted by lifeguardjoe
These??
Old Mar 9, 2004 | 04:12 PM
lifeguardjoe's Avatar
Originally posted by bacamino
NOW that is Hott
the truck
I've got that pic for my wallpaper. If you look closely at the front bumper, you can see about 12 people in the background.
Na, I don't look at the photo much.
