NGK TR6 or IT22's or IT20's or ?
Old Mar 5, 2004 | 03:00 AM
ND4SPD's Avatar
Want to change my plugs, L has 6lb lower, chip, borla cat back, K&N, 4:10, 2000 stall, spray (going to 4lb for spray) what is the best plugs to run for my set up. Thanks!!
Old Mar 5, 2004 | 07:07 AM
Rob_02Lightning's Avatar
4 or 6LB plus Nitrous ='s 2 Zones Colder Plugs needed
I prefer Denso IT-22's @ .038
You could use NGK BRE-7's as a cheaper alternate,
BUT DON'T GO HOTTER
Old Mar 5, 2004 | 10:25 AM
Certified Drunk's Avatar
You can get Denso's pre gapped from Outrageous Preformance for a few dollars more. Just let them know when ordering them.
Old Mar 5, 2004 | 10:40 AM
BigFan's Avatar
LMAO, What has the Community come to when you are paying extra to have plugs gapped ? If you have to pay to have plugs gapped then you shouldnt be replacing your plugs, pay somebody.
BTW- Take Robs advice but he forgot to remind you about the timing
Old Mar 5, 2004 | 11:23 AM
wydopnthrtl's Avatar
If your spraying I'd suggest IT-20s
Rich
Old Mar 5, 2004 | 12:39 PM
Dan_03Lightning's Avatar
I am only speaking from experience, definitely agree you need a colder plug. I have tried the Denso IT 22's (they are an awesome race plug if they hold up - Rob has had great response from them), the AR 93's that was the next plug I tried after the 22's and I was unhappy with the smoothness and throttle response so I went to the Beru "silverstone" S1K's and they have been in my L for 3000+ miles of which I run my race program 100% of the time. I noticed immediate throttle response and improvement in day to day driving. I am a true believer in the Beru's. I am running a KB, 16lbs boost no NOS for what it's worth.
Good Luck on your decision!
D-Day
Old Mar 5, 2004 | 03:39 PM
LightningCT's Avatar
i have the denso IT20's in now...definately felt the difference when they were first put in.....put on 9k since then.....
