Zex kit has arrived!
Old Mar 5, 2004 | 02:06 AM
I8ACAMRO's Avatar
Zex wet kit has arrived.
[IMG][/IMG]
Thanks Rob_02 for the bad influence and great info!
Does anyone have pics of bottle mounting?
spark plug opinions would be nice too.
Old Mar 5, 2004 | 02:13 AM
dirtchicken's Avatar
In the bed behind the drivers seat.
Old Mar 5, 2004 | 03:13 AM
denny0328's Avatar
how much of a shot are you planning on running? im debating between nitrous, or a ported blower...
Old Mar 5, 2004 | 04:29 AM
Just a small 100 shot. Nothing major.
Old Mar 5, 2004 | 05:48 AM
Rob_02Lightning's Avatar
THAT WHAT I'M TALKING ABOUT
You may have to change your name to "I 8 EVERYTHING"
now Judd, CONGRATS
Every Step by Step Pic of my Install is in my Gallery if you need it
https://www.f150online.com/galleries....cfm?gnum=1385
Some mount the Bottle in the Cab behind the seat, "sideways"
by removing the tool box (I prefer the standard tilt and direction)
I also wanted it to be quickly and easily removable, so I still have
full use of the 4ft x 8ft bed
This is what I came up with
Went to Home Depot and found Steel 1/4-20 inserts,
I drilled 4 proper sized holes in the floor, and used "liquid steel" to hold them in
Old Mar 5, 2004 | 05:56 AM
Now I can carry the Bottle, Brackets, and Bottle Warmer out in
one assy, simple put 4 bolts in, and hook up my two wires, using
male by female spade connectors, and the Nitrous Line, and I'm fully functional within a minute or so.
When it's not in use, everything tucks away behind the wheel well, out of the path of the bed.
You can see what I mean here, but those are the first ugly brackets I made
Gator made me these Brackets (THANKS PAL) and it's what I use now. (Notice we changed the angle even more)
Of course the easiest is further up front in the bed where you simply remove the rubber plug in the bed thats already there,
but I can reach in and turn on and off the bottle my way by simply opening the tail gate (of course you can use an electric bottle opener too and put it anywhere) The main thing is mounting those brackets they give you "to something else", "then mount that to the floor". If you look at those brackets, it's dam near impossible to get to the bolts to take the brackets in and out.
GO TWO ZONES COLDER PLUG, I prefer Denso IT-22's gapped @ .038, or you can use NGK BRE-7's (is it ?)
BEST OF LUCK BRO AND CONGRATS
Old Mar 5, 2004 | 09:30 AM
bad00's Avatar
I stole the idea from Rob's pictures, mine is in the bed also
Old Mar 5, 2004 | 09:51 AM
SVT150's Avatar
CONGRATS!!
Kinda funny, people can spend thousands of dollars on performance mods, and not see gains that a little purple bottle can do for a fraction of the price.
I guess I been using the wrong bottle
Old Mar 5, 2004 | 12:46 PM
I8ACAMRO's Avatar
Thanks for the pics everyone.
denny0328: I'll be running a 75hp shot, in addition to the 4# lower I already have.
SVT150:
Old Mar 5, 2004 | 12:58 PM
potac's Avatar
That is the kit I am looking at getting but am still not sure if want to run the spray with my 5lb pulley.
Old Mar 5, 2004 | 01:27 PM
Dale-01L's Avatar
Right on...
That should net you 11's for sure as long as the track hooks like it did a few weeks ago..
Watch out though, its addicting stuff, soon enough you'll be reaching for the larger jets
-Dale
Old Mar 5, 2004 | 02:57 PM
denny0328's Avatar
whats you HP/Tq right now without the Nex? Im thinking about this, but ive heard that 450 is all you should go to on a stock lower end...
Old Mar 5, 2004 | 02:59 PM
LatemodelRacer2's Avatar
the power of the bottle
Old Mar 5, 2004 | 03:23 PM
I8ACAMRO's Avatar
denny0328: I dynoed a 411 RWHP and 503 RWTQ SAE with my current setup. With a 75 shot I hope to be close to the 500-600 club. I'll be heading south very soon for a nitrous tune, I'll keep you posted.
Dale, hows the truck? Let me know when you plan on another Bakersfield trip.
Old Mar 6, 2004 | 09:59 AM
mswaim's Avatar
I want to know when your going to install some of that gay colored hardware under the hood of the Cobra. Mine could use some of that feminization treatment too, but I'm waiting on you dammit. I'm not coming out of the closet until you do.
