windshield washer squirt nozzle problem
I am having a problem with my drivers windshield washer squirt nozzle. It will not shoot out the water, It gets it as far as the wiper blade, were as the passanger side shoots at full blast.
I took the hose apart and blew through everything to see if the hose or T-line contentor was clogged. Has anyone had this problem, or can help on me on what to do.
HI!... I had the same problem with my truck. Get a sewing needle or a diaper pin and poke it through the washer nozzle. Use it like a pipe cleaner. I did this and it solved the problem.
Originally posted by don presby
I am having trouble with my squirt nozzle also. I have to get up three times every night.
They have medication to cure that.
You mean to tell me that you guys ACTUALLY USE your wipers
I can honestly say I have never operated my wipers, although I'm dying to see if they actually work. I removed the wash bottle last summer, in fact. Saved a few pounds off the front of the truck, and the engine bay LOOKS better and more open.
You do know that wipers make microscopic scratches in the windshield and in time you'll see them.
Use Rain-x.
Use Rain-x.
You can simple polish out those micro scratches with the polish used to clean glass ceramic stove tops. It will make your window look like it just came from the factory…
Great for getting rid of water spots in the windows as well. Very easy to put on and very easy to take off…
