Oil loss
Old Feb 28, 2004 | 07:38 PM
olefafl's Avatar
Oil loss
I have an '01 with 37K on it. Stock except for exhaust. Got it used in Nov. Been in 4 times for oil leak. (2 for me, 2 for last owner.) I'm now using the extended powertrain warranty up to 100K.
When I picked it up last time from getting the oil leak fixed they replaced the oil pan gasket and the cap bolts that go through the block. I checked the oil when I picked it up, but it was dark. I could see that it was in the okay range so I left. That was Friday night.
Over the weekend I checked it again and I was half a quart down from full. The invoice listed 6 qts of oil.
Does 6 quarts put the oil to the top of the full?
I just checked my oil (it's been 360 miles since I picked it up) and I am low 3/4 qt.
Do these trucks use oil like this normally? It's not smoking (except slight puff on start occasionally) or dripping. I know about the oil in the intake.
Old Feb 28, 2004 | 07:41 PM
1badlightning's Avatar
Head gasket leaking possibly? But I'm not sure if a head gasket leak would be losing that much oil. Maybe others have some better input.
Old Feb 28, 2004 | 07:56 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Exclamation WHAT!
Oil pan gasket AGAIN?
Time for thumb screws and more investigative measures.
Bob
Old Feb 28, 2004 | 08:09 PM
smokingozzy's Avatar
I belive that 6 qts will put the oil level in the middle of the add and full range. So it may look like it is a little low! Jim
Old Feb 28, 2004 | 09:19 PM
olefafl's Avatar
Re: WHAT!
Bob
Responded to your PM.
Before I dropped it off, I put dye in and told them where it was coming from. They still tried to say it was the oil pan gasket again until I reminded them that the dye indicated the bolts above the oil pan gasket.
Second attempt, previous owner - all gaskets replaced.
This fix - engine was pulled (according to invoice) and I assume they would look for dye from head. When I looked before I dropped it off, it didn't look like it (but I didn't pull the engine!)
Old Feb 28, 2004 | 09:56 PM
EZGZ's Avatar
I thought you needed to use a black light for seeing the dye?
Sounds like they are avoiding the expensive extensive fix. Don't know why? I thought that stuf was covered by the factory warranty. They should make money on it.
Old Feb 28, 2004 | 10:16 PM
olefafl's Avatar
I used a blue led pen light. Works better if you have the yellow glasses. 2-3 tools trucks stop by my work every week. I can get the black light, but I would only use it on my truck. Not something I would use at work, so I didn't spend the money on it.
I don't know why Ford/dealer didn't put dye in the first time, cost me $7.00 on the Mac truck. It has cost Ford $1090.84 just for my 2 fixes and a rental car. I think Ford pays less than a customer for the same work.
Old Feb 28, 2004 | 10:50 PM
theperfectstorm's Avatar
6 quarts will not show up as full on my dipstick. A little over halfway between the two lines on the dipstick.
My 2001 burns about 1/2 quart every 600 to 700 miles, allways
has. A little bit of that is still getting sucked into the intake, even
after I put a oil seperator on it over a year ago. I have a LOT less
oil in the intake however since adding the seperator.
I traded in a 99 lightning that did not burn any oil!!
Mine used to smoke on start up most days, but when I had my charger off for porting I took the intercooler out and cleaned it
up good and so far no smoke.
Old Feb 28, 2004 | 11:56 PM
desertL2001's Avatar
Yup, ditto here. 6 qts isn't all the way full on my '01.
Even with my "recycling" of the PCV oil that I catch with an oil separator, I still use almost 1 quart ever 3500 miles. Must be burning it since it doesn't drip. Mine has 41K miles, about the same as you, basically stock.
Randy
