Aptenized Magnum with Graphite Rotors
Old Feb 27, 2004 | 06:24 PM
My Red-Rocket's Avatar
Question Aptenized Magnum with Graphite Rotors
Do you guys thinks it's possible to aptenize a magnum blower and then use a graphite coated rotor pack? What exactly are the benefits of using graphite rotors? If it's possible this combo. would kick a$$. Thanks.
Old Feb 27, 2004 | 06:44 PM
wydopnthrtl's Avatar
Brian at Apten could answer this far better than all the armchair engineers could.
Rich
Old Feb 27, 2004 | 06:55 PM
l-menace's Avatar
He's done Kenny Bells, so I'm sure Magnum powers could also be done.
Old Feb 27, 2004 | 09:15 PM
Deus's Avatar
If you are going to spend that much cash....why not just opt for the KB?
Old Feb 27, 2004 | 10:54 PM
Not sure but I think this combo would come out to be around $500 less then KB. Don't know too much about graphite rotors though. Someone want to point me in the right direction please. Thanks.
Old Feb 27, 2004 | 11:14 PM
Shorty's Avatar
This blower thing is getting out of hand. Good for us.
Old Feb 28, 2004 | 12:24 AM
Tim Skelton's Avatar
No way that any Eaton will be worth only $500 less than a twin screw. It's not even in the same league.
A roots can never be a compressor, just a blower. A twin screw is a true compressor (and a positive displacement blower).
The KB has the same boost curve as the Eaton and is simply more efficient across the board. Especially when overspun, a twin screw can stay in its efficient range, while the roots' efficiency drops off the map. In a recent test, at 9 PSIG, the Eaton outlet was 207 degrees, while the KB was only 165. Assuming an ambient temp of 70, the Eaton was about 35% hotter. At higher boost levels, the KB will just pull away from there.
Save your money -- no amount of porting or rotor coating can close the gap.
Old Feb 28, 2004 | 10:28 AM
Chikenears's Avatar
Tim Skelton,
I don't want to hi-jack this thread but please email me, I have a favor to ask.
Tim@Chikenears
Thanks,
Tim
