Alignment?? PLEASE HELP!!
Old Feb 26, 2004 | 04:47 PM
Silver 2002's Avatar
Ok, I got my new tires and I called & made an appointment to have the put on tomorrow. I was having some serious vibration and uneven tire wear problems. I am also scheduled to get an alignment tomorrow because most of you on this board tell me that alignment is my problem. I spoke to the guy from the alignment shop this morning and I told him that some of these trucks need the 'camber bolt kit' from what I have heard. He said "they will check that & will let me know if I need it." Also, there are not alot of Lightning's around here and the guy on the phone even asked me "what is a lightning"...so...my question is ....is an alignment on a lightning the same as a regular f-150. Is there some different specs I should give these people? I want to get this done right and get rid of this vibration! What can I do, what do I need to tell them? Please help!! Thanks!!
P.S.- If there is different specs, can someone please give them to me.
Old Feb 26, 2004 | 05:01 PM
SVT_KY's Avatar
Try here ... Lightning Alignment Specs
http://www.mdsonline.ca/Lightning%20...ifications.pdf
Old Feb 26, 2004 | 05:51 PM
So should I give these specs to the alignment shop? Would they have this?
Old Feb 26, 2004 | 06:07 PM
Should I give then the "Lightning specifications" or "Lightning owner preferred"?
Old Feb 26, 2004 | 06:39 PM
Fear Itself's Avatar
I think the "Owner Preferred" are the setting people are using if they race their trucks on road courses. If tire life is not important and you want your truck to handle it's best go with them. However, I do remember reading that those setting would shorten tire life considerably. Something like 50%, I think.
David
Old Feb 27, 2004 | 09:43 AM
So I should just give the the normal "Lightning specs". Also, & this may be a very dumb question but...Does it matter if I have 2inch shackles on the back? I mean as far as these specs being accurate? Thanks for your help guys!
