Leaky Head Gasket
Old Feb 22, 2004 | 12:11 PM
Sharpshooter's Avatar
Leaky Head Gasket
I went and did some 1/4 mile runs with the G-tech yesterday with a friend. He did his first, he did 2 runs back to back with no cool down. When he came back he had a burning rubber/oil smell coming from his motor.
Then I did mine, just like him, I did mine back to back. When I got done I had the same smell, but I had smoke coming from the passenger side of the motor.
I did a search, and found that there are 2 possible causes for the smell; belt slippage or passenger side head gasket.
If mine is the head gasket, do you think my mods caused the problem, or is it something that ford did?
I ran the truck some more last night after it cooled down, and it seemed to run fine, no smells or smoke.
Old Feb 22, 2004 | 12:28 PM
01 XLT Sport's Avatar
Not an expert, but I would say if you smelt burning rubber it was your belt slipping as there is nothing, at least nothing I can think of, as far as a leaky head gasket that would smell like rubber.
Old Feb 22, 2004 | 07:23 PM
Can a leaky head gasket be detected by a compression test?
If it’s the problem that is common with these trucks would it be the rear passenger cylinder?
Do I have a chance with a warranty repair?
The truck seems to run fine other than when I do a couple 0-105 mph blasts. My 1/4 tests with the G-tech were way lower than I expected.
-Mike
Old Feb 22, 2004 | 07:38 PM
VINNIE's Avatar
Sounds like a leaky head gasket and yes back passenger side is were mine was leaking.
Just take a look at the idler arm , below the upper pulley for belt dust. If there is none then it might be the gasket.
Good luck either way.
VINNIE
Old Feb 22, 2004 | 07:54 PM
superfords's Avatar
not if its an external oil leak
Old Feb 22, 2004 | 07:57 PM
wantsalightning's Avatar
If it was smoking, I would go with an oil leak. Good luck man.
Old Feb 22, 2004 | 08:32 PM
lightning5.4's Avatar
head gasket
I had the same thing hapen to me on the freeway me and a couple of codra's were playing I ran mine up to about 120 at WOT and the boost was about 13psi when I let off I could smell oil, well about a mile up we stoped at a rest area I too had the dreaded smoke on the right rear of the engine I looked under the truck and could see just a few spots where oil blew back. ok now I washed it down after I got home and have not seen any since not a drop or any smell that was 5k miles ago
Old Feb 22, 2004 | 09:02 PM
VINNIE
What did you do about it?
Did you run it like that before you got your built motor? or Did you have it fixed?
Mike
Old Feb 22, 2004 | 09:16 PM
VINNIE's Avatar
Mike
I had it for about 6 months. I knew I was getting a built motor and it was not that bad. Never got to the point of smoke under the hood , but you could tell when it was on the lift.
VINNIE
