Is there a difference between jack brands?
Old Feb 16, 2004 | 11:13 AM
SpeedJunky's Avatar
Torino (PepBoys) vs. PowerBuilt (Kragen/Autozone)?
Thanks.
-Monty
Old Feb 16, 2004 | 11:59 AM
ShadowBolt's Avatar
Go to Sears and get the Alum. jack. It works great on a lowered truck (I still use my Rhino ramps to get started). It's $161.00 when they put it on sale and only weighs around 35 lbs. I don't use my old heavy jack at all anymore.
Jerry
Old Feb 16, 2004 | 12:01 PM
SpeedJunky's Avatar
Jerry
Would that be the 2-ton jack? Is the 2-ton sufficient? I was told my many others that a 3-ton is a must.
Thanks Jerry.
-Monty
Old Feb 16, 2004 | 12:18 PM
SpeedJunky's Avatar
26 views and no one else has anything to contribute?
-Monty
Old Feb 16, 2004 | 12:23 PM
easterisland's Avatar
I have a two year old aluminum jack that I can lift of the back of my excursion with.
Old Feb 16, 2004 | 12:27 PM
desertL2001's Avatar
Just my $0.02, go to a garage service supply and check out the selection. The place I went to had a huge range all the way from el-cheapo to the really nice Lincolns (even the lower end Lincolns are imported now). If you plan to use it a lot, just make sure that parts are available for them. Jet has a nice dealer network.
Just about all of them are made in China nowadays, some are better than others. I have a Jet 2-1/4 ton wide-footed steel service jack. Works great. I just rebuilt it after 6 years of use. Rebuild kit was about $10.
Old Feb 16, 2004 | 01:40 PM
SVT_KY's Avatar
3000 pounds should do it ...
http://www.samsclub.com/eclub/main_s...cfkjdgoodflf.0
I got one that looks a LOT like this one at Harbor Freight
and it cost me $160 ... I think it was 2 1/2 ton though.
SEARS has this one ... at least it's a CRAFTSMEN, but check to
see on the warranty, seems lately the only they warranty for
life anymore is the tools.
http://www.sears.com/sr/javasr/produ...id=00950239000
Old Feb 16, 2004 | 02:28 PM
ShadowBolt's Avatar
I stand corrected. The Sears jack is 4000 lbs.
Jerry
Old Feb 16, 2004 | 02:57 PM
zbornac's Avatar
This is the jack I've got, works great on lowered trucks. It lowers very slow as well.
AC DK20Q Hydraulic Jack
http://www.alltiresupply.com/Merchan..._Code=SJ_MQLSJ
-Kimball
