How much boost?
Old Feb 15, 2004 | 06:52 PM
wantsalightning's Avatar
Question How much boost?
How many lbs of boost will the 5.4 handle?
Old Feb 15, 2004 | 06:56 PM
NTIMD8's Avatar
Stock 5.4L from a Lightning? It all really depends on many factors including Timing and A/F ratios.
Man I cant even type the word timing without thinking of Rob.
PS, one of the best features about this board is the search button up at the top. It looks kinda like this
Old Feb 15, 2004 | 06:58 PM
I was wondering b/c Kenne Bell has a twin screw for the L that can add from 9 - 22 lbs depending on the lower pully. That seemed kinda high to me.
Old Feb 15, 2004 | 07:07 PM
NTIMD8's Avatar
Well in that case you also have to remember that you are not really conserned with PSI you are more conserned with volume of air. I.E. 15psi from a stock Eatons blower is safer then 15psi from a KB blower.
Hence why I said you have to look at Timing and A/F ratios. Detonation is not your friend
Its unfortunatley nto as easy as a matter of how much boost you are running.
General rule of thumb that I read is that a stock block can handle about 450hp.
Old Feb 15, 2004 | 07:11 PM
Thanks for the info.
