How to clean oil out of the intake tube area
Old Feb 15, 2004 | 03:38 PM
Jkstang78's Avatar
I am talking past the throtle body, and in to the super charger. Has anyone just spray intake cleaner in there to clean out what ever **** may be in there. I don't not plan on taking the charger off.
Old Feb 15, 2004 | 03:51 PM
l-menace's Avatar
it is real easy to remove!
The gaskets are reusable.
Do it right the first time so you don't have to do it again. (add oil seperator or block off plate)
I STRONGLY DISCOURAGE anyone from spraying cleaner in there.
The cleaner will have to remove oil residue. Then it is going to mix with the oil in your crankcase, If not crankcase, then in the combustion chamber...
Plus who knows what it will do to the Teflon coating on the rotors.
Remove it, soak it in Brake Cleaner, install it.
(45 minutes to an hour for a complete job)
