SC rotors
Old Feb 15, 2004 | 01:30 PM
EZGZ's Avatar
SC rotors
Been waiting for this topic to get covered but not seeing anything.
With all this wasp and SC porting it has me thinking about doing something myself.
Doesn't do much good to throw mods at something if the rest isn't in top shape. Everything works together, doesn' t help your gains in one spot if your weak in another.
When I did my intercooler upgrade I saw the teflon flaking on my 99 L . I read some stuff about a black coating and from time to time people comment on wether there rotors are in good shape or not.
Other than clogging my intercooler will that stuff burn up and go out the exhaust?
Do any of these porting people address this?
Does it get progressively worse or just what?
Is it just the early Eatons that did this?
I would like to get the whole poop on this. Any reference to links would be great.
Old Feb 15, 2004 | 01:37 PM
l-menace's Avatar
You are noticing the teflon flaking off your rotors and clogging your innercooler.
You have a few options:
1. purchase graphite rotors (contact APTEN)(Big $$$$$)
2. Apten can have them re-coated with something (don't think it is teflon)
Does it hurt efficiency? I don't know about the Blower, but clogging the innercooler is BAD NEWS.
Luckily my Eaton is NOT flaking. But it's a '99 with low mileage though.
I would contact Brian at Apten (his shop is authorized by Eaton to service this blower)(No one else is) and he can give you infintely precise information regarding the flaking teflon
Old Feb 15, 2004 | 01:45 PM
EZGZ's Avatar
Thanks!
Mine has 35K miles.
How do you know yours is ok?
Can you see it without pulling the whole top?
Anyone else have any experience on this? Would love to know all my options.
Old Feb 15, 2004 | 01:48 PM
easterisland's Avatar
Are you sure? The last time I checked only Magnusson was autorized to service Eaton blowers...Maybe I'll call them(Magnusson) Monday just to make sure...they may be interested to know someone else claims to be an authorized service center.
Old Feb 15, 2004 | 02:29 PM
Apten_Tech's Avatar
We never claimed to be eaton "authorized". Magnuson has an exclusive deal on that, so eaton will not authorize anyone else to do rebuilds. We do rebuild eatons because we have found a source for OEM parts.
Brian
Old Feb 15, 2004 | 03:09 PM
Rob_02Lightning's Avatar
GREAT TOPIC EZ
For all you people that have been disagreeing with Chuck over this, LOOK AND LEARN
My Rotors are the Graphite Color ones (still have ALL the teflon)
The other Rotor's are from V's 01 Eaton running 8lbs of Pulley
After seeing them is the reason I pulled my Nose and Rotors and put my orig nose and Rotors in my WASP (which was actually V's old Eaton I sent out to WES)
Does him running 8lbs have something to do with the flaking,
probably, maybe, who knows??? but ANYTHING MORE THAN 4 (or maybe 5/6 LBS) AND YOU ARE CLEARLY OVER TURNING AND OVERHEATING THE EATON Schitt in my L, you guys know I run faster with 4lbs than 6 because of the extra heat, I've proved that over and over season after season with better 4lb ET's to show it.
This is the MAIN REASON I choose porting, so I can go back to 4lbs and have more power than running 6lbs, and have the same or more boost, and with less heat in the S/C
AND MOTOR
Since V isn't using these Rotors anymore, hopefully he don't
mind me showing them to you (he will, but FU V, I'm showing them anyway) hehehehe
NO SUCH THING AS OVER TURNING AN EATON HU ???????????
Did it affect performance for him, --> NO
He was running consistant 11's for 2 seasons right up til he
decided to go built motor/kb, but ones got to assume the S/C
IS NOT the only part of the motor showing excessive and premature wear due to the extra heat. I've spend much time with 3 filter systems and now the JLP air box to assure the coolest air
enters my S/C (of course spraying sub zero Nitrous helps too)
My original Rotors were as good as the day they were born, and are now back in my Wasp and back on my Black Beast
Old Feb 15, 2004 | 03:28 PM
Someone needs to get their story straight...
Old Feb 15, 2004 | 03:30 PM
l-menace's Avatar
whoops confused magnum powers with Magnuson.
Brian
http://www.magnumpowers.com/tbrd_dlr.html
(COPY AND PAST FROM WEBSITE)
Authorized Magnum Powers Dealers
Apten Performance - Our goal is to develop performance products for Ford vehicles that surpass today's standards. Apten works with highly specialized experts in different areas to bring our customers only the best. Not only can we provide performance engine products, but we have custom computer chips to fully maximize your vehicle's performance and efficiency.
Apten Performance
Phone: (314) 276-9608
Super Coupe Performance (SCP) - The place to purchase all your Thunderbird Super Coupe and supercharged Cougar XR7 performance products. SCP offers headers, high flow exhaust down tubes, large diameter cat-back exhaust systems, hi-flow C&L and ProM mass air meters, hi-flow throttle bodies and a host of other performance enhancing items for the 3.8L SC engine. They also offer custom 17" and 18" custom wheels with the unique Tbird/Cougar bolt pattern, spring lowering kits and other suspension upgrades, high performance brakes, headlight upgrade packages, upgraded driveline and transmission components and much more.
www.supercoupeperformance.com
Phone: (513) 697-6501
sorry I got it confused....... I confused magnum powers with magnuson..... HONEST MISTAKE
clonetek's Avatar
pics of my intercooler after it was changed out back in 01.
https://www.f150online.com/galleries...40-54-4392.jpg
https://www.f150online.com/galleries...40-54-4394.jpg
https://www.f150online.com/galleries...40-54-4395.jpg
Old Feb 15, 2004 | 03:41 PM
Apten_Tech's Avatar
I think you are confusing magnuson with magnum powers
Old Feb 15, 2004 | 03:45 PM
Pictures of my Intercooler yesterday after 13K of Fun
it was so clean I didn't even pull it and clean it
LIGHTNING ENTERPRISE PCV FIX WORKS WONDERS
Old Feb 15, 2004 | 03:46 PM
l-menace's Avatar
yup that is what I did.
Sorry 'bout that... I thought they were the same company.
Old Feb 15, 2004 | 03:47 PM
LatemodelRacer2's Avatar
Dang Brooks thats one dirty intercooler.
Old Feb 15, 2004 | 04:30 PM
clonetek's Avatar
the chunks were flakes of teflon coming off of the rotors...
Old Feb 15, 2004 | 05:07 PM
Grimace's Avatar
Well, does anyone have any pics of the intercooler, or s/c rotor pack on a stock truck? I have 12,500 (starting to notice the "clunk" but that is another topic) on my 03, and I am wondering if I need to yank the s/c, and clean the i/c. I am running the stock drives, no upgraded pulleys, but I also haven't got the pcv mod yet. Suggestions?
