Help, I'm running lean..
Old Feb 15, 2004 | 11:24 AM
DL's Avatar
DL
Hey,
My 01 L truck has had a problem for months now. The "Service Engine soon" light comes on after a minute or so after starting it up. Looked up the code at my local Ford dealer, It said banks 1 and 2 lean, which means both sides of my engine are running lean. It has been doing this for months, I thought I had a vacuum leak around the fiberglass power tube, but no leaks.
Hooked the truck up on a Dyno this weekend to have some new programs burned and the truck showed lean on the graph, no matter what we did. We could get it down some but , not enough to tune.
I installed new larger fuel pumps and 50 lb injectors this weekend while dynoing, still the same problem. Some kind of electrical gremlin not letting the truck get more fuel? You can hear the fuel pumps activate, Maybe one fuel pump is working and under WOT the other pump is not? Also, sometimes it will start hestitating during cruising around, like it is starving for fuel.
Codes from this weekend was 1639, 0703, 1780, 1408, 1232, 1000... Checked the relays, seemed OK, Fuel press is 54 -56 lbs under WOT?? I've heard someone else on the boards had similiar problems, they took a resistor out of the fuel pump circuit, which allowed the fuel pumps to run wide open all the time, I would rather fix the problem, then remove parts.
Anybody have any suggestions? I'm going to the dealer on Tuesday.
tks
Old Feb 15, 2004 | 11:34 AM
superfords's Avatar
what is your MAF voltage and BARO frequency?
also what kind of percentages are you getting for long and short fuel trims?
BTW:
P1639 - Vehicle ID Block Not Programed Or Is Corrupt
Description:
This diagnostic trouble code (DTC) indicates that the vehicle ID (VID) block is not programed or the information within is corrupt.
Possible Causes:
New PCM
Incorrect PCM
Incorrect VID configuration
(or your chip)
P0703 - Brake Switch Circuit Input Malfunction
(most likely somebody performed your KOER test incorrectly or incompletely)
P1780 - Transmission Control Switch Out of Self-Test Range (again, whoever did your self test did it in a rush or incorrectly and didn't actuate all of the inputs)
P1408 - EGR Flow Out of Self-Test Range (Non MIL)
(have you removed your egr system?, or possible faulty dpfe, or evr or vacuum problem)
and here's the only one that looks like it points us in the right direction:
DTC: P1232 - Low Speed Fuel Pump Primary Circuit Malfunction
Description: The PCM monitors the low speed fuel pump (LFP) primary circuit output from the PCM. The test fails if: When the LFP circuit is commanded on (grounded), excessive current draw is detected on the LFP circuit; or when the LFP circuit is commanded off, voltage is not detected on the LFP circuit (the PCM expects to detect VPWR voltage coming through the low speed fuel pump relay coil to the LFP circuit).
Possible Causes: Open or shorted low fuel pump (LFP) circuit
*Open VPWR to low speed fuel pump relay
*Damaged low speed fuel pump relay
*Damaged PCM
Diagnostic Aids: *An open circuit or short to ground can only be detected with the low speed fuel pump.
*A short to power can only be detected with the low speed fuel pump commanded on.
*During KOEO and KOER Self-Test, the low speed fuel pump output command will be cycled on and off.
hope this helps.
I'd say check your low speed fuel pump relay (check your owners manual for location).
later,
chris
Old Feb 15, 2004 | 11:41 AM
DL's Avatar
DL
Hey Chris,
This may not sound right, but I think sometimes the fuel trim would be like up to 30% lean under WOT??? We used a Ford tool, looks like a big T to check the codes. I'm trying to get in touch with him now, so I can post more info.
tks
Old Feb 15, 2004 | 11:52 AM
superfords's Avatar
look above DL, sounds like maybe one of your fuel pump relays is bad.
P.S. "the big T" is an NGS or "new generation star tester", but I may start calling it "the big T" at work now. I like the way that sounds better anyway. I'll run it past the other guys in the shop. just messin' with ya. good luck on your problem.
later,
chris
Old Feb 15, 2004 | 12:00 PM
DL's Avatar
DL
Hey Chris,
Is that the two relays together beside the fuse box under the hood on the drivers side?
We checked them with a voltmeter and swapped them all around.
Old Feb 15, 2004 | 12:19 PM
DL's Avatar
DL
later,
chris
Hey glad I could help you out..It's cool.. My local Ford dealer tech has the Big T(He!He!) and another one that looks like a big touch screen monitor (portable like a Lap top) I don't remember the abbrev names for the test equipment..
Old Feb 15, 2004 | 12:47 PM
DL's Avatar
DL
Hey Chris,
We tried a new processor, still did the same thing. Must be the relay, I hope.
Can you shoot me an E-mail at dplynn1@bellsouth.net ... tks
We pulled 305 and 306 out, my friend checked them with a Volt meter, then we swapped them back in the opposite number slot? Maybe we didn't check the relay properly? We swapped them, the other should have been good??
Old Feb 15, 2004 | 09:08 PM
tlfwatch's Avatar
Re: Help, I'm running lean..
Originally posted by DL
Hey,
tks
you need to put more fuel to the carburator
Old Feb 15, 2004 | 09:56 PM
easterisland's Avatar
Re: Re: Help, I'm running lean..
Is that what JDM told ya?
Old Feb 15, 2004 | 09:58 PM
99svtlightning's Avatar
DL,
I think you need to install bigger jets in the carb.
Seriously, I'd recommend testing it by bypassing the resistor. Just let both pumps run and see what happens. Also, did you try swapping MAF's from another truck?
Old Feb 15, 2004 | 10:29 PM
bdaztrk's Avatar
Hope you come up with the answer to this because I have a 03 with the same problem. 1500 miles on it I went to get it dyno tuned and it had the same problem, it would rich up a little but it still showed it running lean. Nobody has come up with a answer for me. I hope you get a answer so I will know where to look.
Old Feb 16, 2004 | 11:27 AM
LIGHTNINROD's Avatar
"I thought I had a vacuum leak around the fiberglass power tube, but no leaks. "
David: I HAD a REM intake, 'hard' pipe installed on my 01. I never got any "lean codes" but when I took it off to check for any intake oil, I found two of the three rubber grommets(on the bottom--for the PCV tubes) of the pipe cut or torn. This would certainly allow for unmetered/extra air getting into the mixture. Check them out carefully.
Dan
Old Feb 16, 2004 | 11:28 AM
(Note: REM replaced the grommets quickly but I don't trust that the new grommets will do a better job of staying tear-free due to the design and the sharp edge of the holes.)
Dan
Old Feb 16, 2004 | 02:30 PM
DL's Avatar
DL
Originally posted by 99svtlightning
DL,
Put a brand new MAF on the truck last week at my local dealer, two new 02 sensors. At the Dyno, we threw alot of fuel at it, it didn't lower the air/fuel ratio enough to be safe. I shouldn't have to bypass the reistor, It used to work fine. My local Ford tech said it wouldn't be a good idea to run without the resistor for a long period of time.
Got a appt with my dealer for either tomorrow or Wed. , we'll see.
Thanks Dan, we checked for vaccum leaks, I'll check there also.
Old Feb 16, 2004 | 03:57 PM
Justin@JDM's Avatar
Banned
The real meaning behind the code is that the truck is running too rich and the computer is trying to lean it out. If you have an oil breather cap try putting the stock cap back on. Not referring to DL's problem directly.
Justin@JDM
