misfirering at wot
Old Feb 12, 2004 | 07:35 PM
Probleminfected's Avatar
misfirering at wot
ok.
so i've noticed lately that when i'm going 60 then stomp on it to wot, i start misfiring
today i had the music up so loud i didn't hear it and the freaking engine killed at 70mph, so i put it in N and started it back up.
everything rans fine at part throttle and at idle. even when i rev it up all the way to 5500 no misfire
i pulled my chip and that didn't help.
i pulled #1 plug it looked fine, didn't have time to look at the rest
this is a new thing, and i've had the same mods for almost a year now
now it might be a couple of plugs that can't jump the gap at wot and full boost
or it might be that i'm not getting enough gas at wot
thats all i can think of
what do you guys think ???
Old Feb 12, 2004 | 07:40 PM
cpeapea's Avatar
spark blowout?try gapping a little closer? or could it be a clogged fuel filter?
Old Feb 12, 2004 | 07:44 PM
if the spark plug blew out it would do it all the time
i'm gapped at .034 right now, but the others i didn't check might be fouled
changed the fuel filter yesterday, still doing it
Old Feb 12, 2004 | 07:52 PM
smokingozzy's Avatar
Maybe a bad coil pack? Jim
Old Feb 12, 2004 | 08:08 PM
svtdvm's Avatar
If you continue to have problems, rule out these as the culprit: fuel filter, plugs, coil packs, and fuel pump
Old Feb 12, 2004 | 09:46 PM
tlfwatch's Avatar
Thumbs up CHECK YOUR THROTTLE POSTION SENSOR
Check your TPS
Old Feb 12, 2004 | 10:03 PM
SLVRLTNG's Avatar
If you're running Denso's that's the same problem I was having.. I pitched them and put in NGK's. no more misfire....JR
just my opinion...................
Old Feb 13, 2004 | 01:16 AM
yeah, i do think its my plugs.
i went over to napa, and asked for br7's but there is a bunch of different types of those.
which br7's do i want ?
they had tr6's but they are one heat range to hot
Old Feb 13, 2004 | 02:22 AM
Bad as L's Avatar
I think its a BR7EF but that is just from memory.
My input is this.....some levels of detonation feels like a misfire, you can't really here it....just feels like the engine is cutting out a little.
