Boost problems! please help
Old Feb 9, 2004 | 06:46 PM
CaliLightning's Avatar
Talking Boost problems! please help
I am having problems with my truck building boost when warm. I have 15k on a stock long block and 400 miles on a new supercharger. Ford thought that the blower was my reason for lack of boost so they replaced that along with a new intercooler. So now im looking for other reasons??? its a 2000 lightning with a 90mm MAF, Single SVO T/B, superchip. is there any hoses i should check etc? any help is apreciated thanks
Old Feb 9, 2004 | 06:49 PM
JDM02SVT's Avatar
That's a new one for me bro...hope you get it figured out
Old Feb 9, 2004 | 08:04 PM
LatemodelRacer2's Avatar
I bet it has somthing to do with the boost dump actuator.
Old Feb 9, 2004 | 10:27 PM
RED 92's Avatar
Dose the dealer say its compressor surge. ..the supercharger is creating boost, but the throttle shaft is closed.
1st Unplug your boost dump actuator., its on the drivers side and see if that makes a difference.
you could check TPS sensor and adjust the sensor voltage if it is low.
Check your Passenger side PCV lines. Pull the line going to the lower intake( from the tee to the plenum) while its idling and make sure it has vacuum.
Old Feb 10, 2004 | 01:34 AM
Well the dealer told me the reason for loss of boost was that the blades were melted and the coating came off them and clogged my intercooler...I had the dumb boost deal unplugged, is there any other way boost could be escaping?? Also what should the TPS read when i check it? thanks
Old Feb 10, 2004 | 01:45 AM
speeder's Avatar
Im with LatemodelRacer2, it sound like your boost actuator is not working, thats about the only thing I can think of that would keep your truck from building boost.
Old Feb 10, 2004 | 08:34 AM
RED 92's Avatar
The only way your not building boost is your vanes/lobes are worn or the eaton is not turning...........but you replaced that.
Your problem is what the engine is doing with that charge when hot..... stuffing part of it into a cracked intake galley leaking into the crankcase...just reaching here...
so your eaton is working, its delivering a fixed volume of air per rotation.......your tuning/timing might be "off" it its not craming the full fixed volume of compressed charge in.
Do you have the stock throttle body to try......or did it run OK since you had the SVO T/B.
Old Feb 10, 2004 | 01:10 PM
LIGHTNINROD's Avatar
What makes you think it's not building boost? How do you know that? If you're just looking at the OEM boost gauge, it can be way off.
Is the s/c'r belt slipping, too loose, etc?
Dan
Old Feb 10, 2004 | 03:27 PM
99WhiteBeast's Avatar
Check this thread- shot in the dark but worth checking out.
loss of boost
Old Feb 10, 2004 | 04:47 PM
Well looks like im going to be getting a vacume gauge this weekend and finding out what my vacume is..Does anyone know what i should be reading at idle and driving conditions? thanks
Nate
