Ported Blower
Ported Blower
Think i'm going to go with one of the ported blowers but have a quick question. Is it easy for Ford to tell that its ported without actually taking it off? If its not that easy then sign me up. Whos getting the most gain right now?
Re: Ported Blower
My suggestion would be to not mod it if you are wanting Ford to pay for a screw up.
Nothing personal my friend, but why should Ford pay for rod failure because YOU chose to sock extra boost to the engine.
Rocks
i in no way want ford to cover for my screw up. All i want is to be able to pull into the dealership for a suspension problem or something completely unrelated and not walk out with a voided warranty for no reason. so i take it you cant see any change from the outside.
Rocks
Oh, by the way...modding part of the motor is not suppose to cause a voided warranty on a totally unrelated part.
it doesn't matter if it is ported or not.
the dealership MUST PROVE that the porting caused the failure.
It should be that wat, but from my own experience it isn't that way.
Maybe some dealerships would help you out, but the 2 I have been to wouldn't.
they have to prove that the modification caused the failure to void a warranty.
If they saw all my mods and said my warranty was voided due to it, and it was unrelated, I wouldn't screw around. Straight to court.
Buit my truck has been out of warranty for a while ('1999 with 16,000 miles currently) (too old, no extended warranty)
Ford does this B.S. because they think they can get away with it and no one will challenge them. No one sticks up for themselves.
Re: TO ALL WHO PLAN TO HAVE BLOWER PORTED/??
Originally posted by tlfwatch
They will be more vendors who will be porting blowers which is good. but make sure you are tuned for it if you are running pulleys chip cold air etc/ timing is an important key to much timing plus detonation can result in "BOOM" then its all over/
Uh...Pat....I would like to buy some punctuation marks.
Rocks
My question is this. Would porting my eaton be bennificial with no other mods at all? I only have a panel filter, and cat-back. I just want more go, but I don't want to add pulley's and chips yet.
