KB at 12 lbs. of boost. sound safe on a stock block
hey guys i was wondering what u think about a KB running 12 lbs. of boost on a stock block? And also could you post vids of KB dynos or runs down the track.
Thanks,
Simon
Thanks,
Simon
I have been running that same combo for about 13 months on 91 octane Ca gas. No problem at all. Makes 436 hp and 500 torque. I can even tow my boat with it. If you have a good tuner, you should be fine. Skip
if thats all the boost your going to run, why not stay with the eaton and spend the same amount of money elsewhere, and be faster. unless theres a built shortblock in the future.
just something for you think about, anyhow, good luck.
later
chiz
later
chiz
the built engine might be in the future depending on how hard i push the KB on the stock block. but chiz i understand what you are saying. thanks for the replies guys. anymore KB users who want to put in their opinion would be appreciated.
thanks,
simon
thanks,
simon
I wouldn't spend the money unless you planned on more than 12 psi. If both pump out enough for you to 12 psi means that the air being pumped out by each is approximately the same. The KB will need less HP to drive it and also deliver cooler discharge air temps. I don't think the difference would be worth the hassle for a measly 12 psi. But, if you have the cash go for it.
BTW, the KB moves around 2.3L per revolution at 100% efficiency which is more than the Eaton(approximately 1.86L per revolution at 100%).
Also some people have complained that their KB blower has locked up or the bearings have went bad.
Click on my sig pic for some videos and you can see my F150 online photo gallery for some pics of dyno sheets.
later
chiz
later
chiz
Just watched some of your vids...sweet truck btw. But that one street racing vid is crazy! Were you there or did you just get a copy of it from someone...just wondering if anyone ended up seriously hurt?
