Where does it go?
Old Feb 6, 2004 | 09:17 AM
krueger's Avatar
Where does it go?
what do you do with the air temp sensor in the air cleaner ***. when you get a new 12 cone filter ? I dont see where it goes.
First time using one
Thanks for any help
krueger
Old Feb 6, 2004 | 09:23 AM
TiresWinRaces's Avatar
Hmmm, on my Airforce 1 kit, there is a hole in the rubber "neck" between the filter and the MAF for it. What kind of filter did you get?
Old Feb 6, 2004 | 09:38 AM
yysenhimer's Avatar
The JDM one came with a new sensor installed.
halflife's Avatar
u can just let it hang there. mine had a hole in the rubber end of the filter to fit it in. maybe you can make a small hole in the rubber boot.
Old Feb 6, 2004 | 09:39 AM
Chikenears's Avatar
Re: Where does it go?
Thanks for any help
krueger
Drill a 3/8th's inch hole in the rubber on the back side between the clamp and the filter element. It's a tight fit but that's where you plug in your air charge sensor.
Tim
Old Feb 6, 2004 | 09:41 AM
krueger's Avatar
thanks everyone ill drill the hole
