EGT Gauge Sensor Install Pics
Old Jan 27, 2004 | 02:09 PM
TampaBlack99's Avatar
Anyone got pics of where they installed the sensor for the EGT gauge?
Old Jan 27, 2004 | 02:17 PM
easterisland's Avatar
Old Jan 27, 2004 | 02:18 PM
Old Jan 27, 2004 | 02:27 PM
Konig's Avatar
talk about fast service.....
Old Jan 27, 2004 | 02:49 PM
Old Jan 27, 2004 | 05:27 PM
RollinLimp2001's Avatar
Ok so when someone is selling a pyrometer it's just the probe? Then you need the EGT gauge to correspond with the probe? Also what's the differences between all the different versions of that probe? Thanks.
Old Jan 27, 2004 | 05:32 PM
Mostly I think the more expensive ones are probably more accurate. Some clamp on some you have to weld a bung on the exhaust some you tap and thread a fitting in like the ones pictured above. BTW, they don't leak. Some kits may include the probes...
Old Jan 27, 2004 | 07:49 PM
Fordsrus's Avatar
Dose the clamp on work just as good as the thread in probs.
Old Jan 28, 2004 | 11:12 AM
MISTERgadget's Avatar
Welded on the bung included in the kit. In the picture i just had a brass plug in it.
The autometer harware included with the sensor or gauge threads right in. Since it's NPT it tapers and will not go in all the way. Set it up so the probe is about halfway into the tube. The autometere instructions have specific measurements.
Old Jan 28, 2004 | 01:07 PM
NTIMD8's Avatar
I don't want to alarm anybody but there is a big hairy toe in that picture!
Old Jan 28, 2004 | 10:52 PM
captainoblivious's Avatar
I don't believe so.
Definately a great thing to use to monitor engines.
