Apten porting pulley combo
Old Jan 25, 2004 | 12:49 PM
ub2slo's Avatar
Question Apten porting pulley combo
What kind of pulley are you using with the Apten ported blower? I have a 6# on the truck right now but wonder if it's still safe after porting the blower. Is a reburn necessary?
Old Jan 25, 2004 | 12:51 PM
fractaldragon's Avatar
I am installing mine with my 4# lower. I had my chip reburned just to compensate for any small amount of leanness from the porting...
Old Jan 25, 2004 | 01:08 PM
l-menace's Avatar
just sold my 6#, sticking with my 3#, I'm trying to be a litle conservative.
Old Jan 25, 2004 | 01:09 PM
Apten_Tech's Avatar
when you have the supercharger ported it typically adds 1-3lb of boost. So if you had a 4lb lower, it would be adding more like 6lb from the factory. There are some people using a ported blower with a 6lb lower, but that's like 8 additional psi of boost. That's a little scary on a stock bottom end.
Brian
Old Jan 25, 2004 | 01:32 PM
LatemodelRacer2's Avatar
I think the best way to look at it is if you have say a 4lb lower on and you think it is pushing it. You do the apten port you should put a 2lb on or it is like running a 6lb pulley.
Old Jan 25, 2004 | 01:40 PM
s.cal L 2's Avatar
Do you actually gain boost, or just get what you suppose to? Say you have a 6# lower, with the heat it generates and other restrictions you would see around a 4-5# increase. With the porting wouldnt you see the true 6#s?
Old Jan 25, 2004 | 01:44 PM
soap's Avatar
The joys of the east side of the country............we actually see an advertized boost increase.
--Joe
Old Jan 25, 2004 | 01:51 PM
s.cal L 2's Avatar
On my side of the country, we enjoy sunshine all year long, racing all year long and the ladies looking fine all year long. Ill sacrifice on some little extra boost.
Old Jan 25, 2004 | 01:57 PM
svtdvm's Avatar
If you guys are replacing your 4 and 6#’ers with smaller pulleys after porting your blowers, then my question is why bother porting?
Seems to me the power you gain from the porting is negated when you put a smaller pulley on.
Old Jan 25, 2004 | 02:05 PM
soap's Avatar
You bring up very good points
But since this is a Lightning forum we win
--Joe
Old Jan 25, 2004 | 02:06 PM
soap's Avatar
I totally agree........why port the blower then decrease your pulley.
Waste of money IMO.
--Joe
Old Jan 25, 2004 | 02:09 PM
ub2slo's Avatar
Good question, but I feel that when you port the blower your making it obviously more efficient (ex: KB) where you make more efficient power at lower boost levels. Hence you don't put as much strain on the block. I'll be dropping to a 4# lower when I port mine in a few weeks.
Old Jan 25, 2004 | 02:13 PM
Sharpshooter's Avatar
I don't know that it is a total waste.
The Eaton I think is rated up to a certain RPM. With the port job you can spin the blower slower and create the same amount of boost as people with a bigger pulley and no port work.
With that in mind it should give you more potential with the Eaton. The only reason people are swaping to a smaller pulley, is they don't know how much "power" their stock block can handle. I'm sure when people start using the Apten on a built block you may see the potential for alot more boost then you did before.
I'm not speaking from expeirence, but just from what I read. I could be wrong.
Mike
Old Jan 25, 2004 | 02:58 PM
Brian
I was expecting to see about a lb increase. Damn...hope I don't have to drop to a 2# pulley!
Old Jan 25, 2004 | 03:04 PM
Odin's Wrath's Avatar
--Joe
Nope. He can afford to live in Southern CA and drive a Lightning..... He wins.
I think I hate him.
